Question about Schwinn 220 Recumbent Bike
Swinn recombent bike tension not woking
Tension not working, what to do ?
How do i replace crank bearings on my 26 in swinn sidewider
That is called the bottom bracket bearing on a bike. You will need a crank extractor and a cartridge bottom bracket tool. Park Tool has some of the best instructions available:
Bottom Bracket Service Cartridge Type (read their instructions first). You can also look at the following video to see the process.
Be sure to purchase the same length cartridge as you are replacing.
Sep 18, 2017 | Cycling
Were can i get this
Repost in the proper format.
Not a cars and trucks question!
Apr 24, 2016 | Cars & Trucks
How can i get a power cord for my Swinn ex. bike?Estimated to be 5 Years old.
It would help to know what model bike You have because that model number can be given to any appliance parts dealer that You find locally, possibly even Sears, to get a replacement power adapter. I'm assuming Yours is like a small transformer that plugs into the wall outlet with a small cord that has a shiny metal pin on the end that plugs into Your Bike? Adapters for other Schwinn® and Nautilus® home fitness equipment can be ordered by phone at (800) 605-3369. Optional power adapter for the Schwinn® A40 elliptical, A10 and A15 upright bikes and A20 and A25 recumbent bikes. I hope that helps!
Feb 19, 2015 | Power Motorcycles
Healthrider h35xr recombant bike
go to the menu or use the control from monitor and adjust the brigtness ,etc
Otherwise you must tight the ribbon cable, and clean it for dirty, corrosion.
God bless you
Jul 22, 2013 | Exercise & Fitness
Where can I find parts for my Peewee Herman H5speed swinn bike ?
Try a Harley dealer. Or you could buy the parts from Schwinn. They even have a website that sells parts.
Jun 19, 2013 | Motorcycles
Need to know size of ac power cord to get ie. volts and mA for a proform gl 125 recombent bike
hello. Your proform can be operated on electric or with 4 D cell batteries. If you do not have the power supply cord that comes with this unit you must order one from the company. The information on how to order one from the company is at the end of the manual. Here is the manual:
http://fitness.manualsonline.com/mdownloads/ae475852-929e-4cad-8d5a-1ac56f09731a.pdf
Kindly rate my answer. thankyou.
Feb 03, 2010 | Proform 575 Crosstrainer Treadmill
I am trying to replace the chain on a swinn pixie bike--but thereis a chain guard that is giving me troubles--I need to know how to assemble the chain with the guard
see if theres a master link on the chain and take off from that way you dont have to take off the guard. the master link will look diffrent from all the other links and can normally be removed with a screwdriver
Jul 02, 2009 | Cycling
Increasing the resistance on a DP 400 Exercise bike
20 years old! wow vintage ha well it is actually connected my friend but ur bike is well a little oldy for more resistance u see as the bike gets older the wire to provide the tension losses its tension factor or rather its ability to provide tension like our tendons and ligaments so my friend either change the wire if u can or better change the bike lol
Jun 29, 2009 | Exercise & Fitness
Fuel gauge not woking 2006 fi harley softtail standard
Check your fuses and for possible shorted or cut wiring.
Apr 02, 2009 | 2006 Harley Davidson FXDWGI Dyna Wide...
The tension on the recumbent exercise bike does not get hard
If your bike has magnetic resistance and you changed the batteries this should make your tension work properly. Since it did not I believe that there are magnets somewhere on your bike that are wearing out. Or it could be a computer part. Your manual should tell what part you need to order and replace. I hope this information has been helpful.
Also make sure the batteries that you put in your bike are really new ones. Sometimes you can purchase new batteries at a store and they are actually a little weak. I had this problem with an elyptical trainer and I went and got other batteries and this fixed the problem.
Mar 14, 2009 | Cycling
Schwinn 220 Recumbent Bike Logo
79 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
