Question about Genius Gx Hs G550 Lychas Headset
Left ear stopped working - Genius Gx Hs G550 Lychas Headset
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
I have had the bose in-ear headphones for a year and they were great at first and then all of a sudden the left earpiece stops working. If I move the part that connects the headphones to the ipod then it...
If your headphones are in warranty (under a year old) Bose will repair or more likely replace them with a new pair. I am now on my forth pair or Bose in-ear headphones and experienced the same problem with an ear piece stop working. I have to say Bose customer service has been fantastic and has replaced each pair. Every new pair is then covered by a new full years warranty. Unfortunately my fourth pair has just gone wrong with the same connector problem. Bose again have said they will replace as they are in warranty. I have been told if they are out of warranty they will offer a new pair at a discount price of £50 instead of £80. However i think that if my new pair go wrong out of warranty i will have no option but to look at alternatives.A Pair of headphones that cost £80 should last more than a year!!!
Mar 29, 2010 | Bose in-ear headphones - Black with...
Right ear bud isn't working
i have this problem too, except it's the left side that doesn't work. i think that's because the copper wire inside broke or is severed partly. there is no way to fix it... just go buy a new one and this time try to kot coil the cords around hour mp3or ipod.
Oct 27, 2009 | Bose on-ear TriPort Headphones
Left earphone just stopped working -
I just solved my problem. My left earphone wasn't working or would work some of the time with it cutting in and out depending on my head position or if I moved quickly. What I did follows:
1. Took ear pad off
2. Took black liner off of the inside of earphones. Glued on 2 spots.
3. Below the silver band of material is a clear plastic lining that covers the speaker.
4. I pressed that clear liner to see if it helped make the left earphone work and it did.
5. I had to fiddle with it to get it perfect but it worked for me.
I'm sure this would void any warranty and work on your own headphones at your own risk.
Aug 26, 2009 | Bose QuietComfort 2 Consumer Headphones
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Bobbin don't turn
Jul 01, 2009 | Brother SE-270D Computerized Sewing...
No sound
same here..... like..... iwas using them for while by connectin em 2 my projector.. i gues.. i jus kept em aside for a few days.. whn i tried 2 use em again... it jus BLANK.... sum1 plz... totally in need of help
Jun 22, 2009 | Bose TriPort Consumer Headphones
REd ilo mp3 player
im not surebut i have one too and mine r working perfectly fine!
Oct 25, 2007 | iLO (2 GB) MP3 Player
Genius Gx Hs G550 Lychas Headset Logo
56 people viewed this question
Top Genius Radio Communications Experts
TO Lady
Tom Chichester
Clive
Clive
Are you a Genius Radio Communication Expert? Answer questions, earn points and help others
