SOURCE: I cannot install BF 810
The problem is two-fold: correct device driver for the endoscope, and correct driver for the adapter.
Please check with the manufacturer of the endoscope whether that connection expects a standard RS-232 port. They might be able to recommend the proper driver combination to get this to work.
SOURCE: Reqd Software for BF-810
If some body is still looking for solutions to this kind of similar problem. then there are few things to remember about USB to Serial Converter. 1- To get the latest driver go to www.bafo.com. 2- to check the device use Hyperterminal and make sure that the flow control is set to none. 3- to my experience serial programers for microcontrollers do not work with converter, because programmers use more than 2 pins of the serial port(DB9). which are important for the programing of the microcontrollers.
SOURCE: hai mr.igot problem when i install usb bf-810 iwas
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.
Follow the steps below to install Windows® 98 or Windows® ME driver
5.1 Turn on the power of computer and make sure the USB port is enabled and can
working properly.
5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive.
Select “Install Products - USB-SERIAL ADAPTER - Install”.
5.3 Select the “Next” to install.
Follow the steps below to install Windows® 2000 driver
6.1 Turn on the power of computer and make sure the USB port is enabled and can
working properly.
6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive.
6.3 Select the “Next” to install.
Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.
Follow the steps below to install Windows® XP driver
7.1 Turn on the power of computer and make sure the USB port is enabled and can
working properly.
7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive.
7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X)
8.1.1 Power on your computer and make sure that USB port is enabled and working
properly.
8.1.2 Insert the USB adapter software driver into CD-ROM driver.
8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on
"PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303
driver" folder in the desktop.
8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto
install, you may change the driver directory that you want to install.
8.1.5 System will demand restart computer.
8.1.6 Plug in the USB-Serial adapter into USB port.
8.1.7 To make sure that your computer can use the device, you have check the
"Apple System Profile"-"Device and Volumes".
It will show the USB Device.It will show in USB port "USB-Serial Controller".
8.2 Driver Installation (MAC OS 8&9)
8.2.1 Power on your computer and make sure that USB port is enabled and working
properly.
8.2.2 Insert the USB adapter software driver into CD-ROM driver.
8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on
"PL2303_OS9_v136b1.hqx",it will auto run the program and appear
"ProlificUSBSerial" file.
8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension".
8.2.5 Plug in the USB-Serial adapter into USB port.
8.2.6 To make sure that your computer can use the device, you have check the
Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
SOURCE: i install driver from bafo
Download the Drivers usings third party software. If you want use the below link for a free software name Driver Genius Pro. Edition which will able to download drivers for you and also able to update your old drivers too.
Click here for Driver Genius Pro. Edition
