Question about Craftsman Garden
My lawn mower tries to start but then dies shortly thereafter.
I prime my lawnmower and it will run for about 5 seconds and then die. Do you think there is something wrong with the carburetor?
  • Anonymous Mar 30, 2014
    5.5 hp ohv vertical shaft lawnmower crankshaft and al gears
  • Anonymous Mar 31, 2014
    seriel number is 1b164h30108
  • 376 Answers
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
Posted on May 17, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Dynamark 3.5 Model 20211X18A. Looking for manuel, I prime 2 times to start. Engines starts then dies. If I continue to push prime button it will keep running, barely, however, dies as soon as I stop...
Could be 2 things: a restriction in your fuel line/coming out of the tank, or 2: a dirty carburetor needing to be removed, cleaned and possibly rebuilt and reinstalled. Hope it's one of those.Start with pulling the fuel line loose from the carburetor. If you have fuel flowing freely, plug the hose with a golf tee and move onto removing the carburetor. Carb kits are cheap and easy to install. It's best to rebuild while you have it off to avoid similar problems later.
Sep 30, 2013 | Briggs & Stratton Briggs Stratton...
Lawnmower starts when primed only then stops
All mowers have a low oil cutoff. Fill oil. 30w.
May 29, 2013 | Garden
Small engine repair
First check the air filter isn't blocked. If it isn't the carb is at fault.
May 29, 2013 | Briggs & Stratton Briggs Stratton...
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
Lawn mower starts but makes a put put sound and runs for only 5-10 seconds i have cleaned carb bowl replaced fuel line replaced priming bulb and replaced air filter
I hope this helps you. :
http://www.fixya.com/support/r8367428-starts_dies_common_engine_problem
I would recommend using carburetor cleaner and flush out the jets.
Joe
Mar 23, 2011 | Briggs & Stratton Briggs Stratton...
Garden Logo
1,039 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
