Question about Samsung Electric Range Oven Stove For Sale In Kentucky Ky Pick - Up Only
Fcq321htux Samsung Range Model # fcQ321htux An SE Error pops up at various times of the day or night...just a lot of loud beeping. Also the SE Error appears when the range is turned on & oven is on. The oven will shut off showing SE error. Could this be a keypad issue, a thermostat issue or the band strip We recently replaced the board & now have the issue
SOURCE: Samsung Over range Microwave
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
Posted on Apr 17, 2009
SOURCE: My samsung microwave model SMH718 keeps showing an
I had the same problem, I changed the daylight savings time on mine and it worked untill summer, then it happend again. Finally mine quit working altogether. P.S. when this first happend samsung didn't even know what the error coded meant. It is an engineering code, meaning service engineer I believe. If it is beyond the year warranty your hosed, it would cost so much to try and fix your better off buying a new one.
Posted on Dec 07, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a samsung over
Hi
SE error code means shorted key and is displayed when either a key is shorted or the key pad has gone bad. Usually replacing the keypad solves the issue however, before doing this you can also try to leave it unplug for 15 minutes. If the issue returns then the keypad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 21, 2011
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a Samsung Induction
"SE" error means you have a shorted membrane keypad.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or in the back cover, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 29, 2011
  • 33 Answers
SOURCE: Is there a design flaw in the Samsung ranges; i.e.
Any range with a built-in element ( the bottom element not exposed) takes on average 15 to 20 min to preheat. It's not only the samsung ranges.
Posted on Mar 14, 2011
We have the same problem as Kristen with the F68 error on two different Frigidaire FGEF308TNF ranges. Does she have solar panels on her house as we do?
Thank you for your inquiry, Robert Klaum!
I see that your Frigidaire range is displaying an "F68" error code. I am unsure if another member has the same problem due to solar panels. Typically, an "F68" error code means that you have a high voltage condition. This could be an issue with the polarity, supply voltage, or EOC (Electronic Oven Control). I would recommend having a professional technician out to your home for a proper diagnosis to be completed. Best of luck! -Matt
Dec 19, 2014 | Frigidaire Kitchen Ranges
Why does my kenmore range beep and show an error code every time I open the oven door?
See if this helps...
http://link.brightcove.com/services/player/bcpid1910171499001?bckey=AQ~~,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1974107068001
Also
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code.
Also
F3 or F30 means that there may be a problem with the oven sensor.
Your oven sensor may need to be replaced.
Jul 08, 2014 | Kenmore Kitchen Ranges
I HAVE A SAMSUNG MICROWAVE MODEL SMH8165ST KEEPS BEEPING SE
"SE" error on a Samsung made microwave means you have a shorting membrane keypad.
This is a pretty simple DIY repair.
You would need part number DE94-01806C which you can get for about $68 from the Pros here, our favorite supplier.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then unplug the keypad strip and move your board into the new frame. Be careful, because the display is made of glass.
Some connectors on the relays have a lock:
Jan 29, 2013 | Samsung SMH9187ST Microwave Oven
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
When I pushed the bake oven button on, I heard a loud pop! I thought a light bulb above my range (microwave oven bulb) blew out. Then F1 came on the range screen. We turned off the power to the range...
The F1 error code means one of two thing;either the touchpad is bad or a relay on the conrtol has shorted out. Well the loud pop and the F1,their is not doubt that a relay on the control has indeed shorted out. The fix for that is to replace teh control
PLEASE NOTE A SHORTED RELAY WILL MAKE THE HEAT ELEMENT TO STAY ON AT ALL TIMES AND THE BREAKER MUST BE LEFT TURNED OFF AT ALL TIMES UNTIL THE CONTROL HAS BEEN REPLACED OR IF LEFT ON THEIR WILL BE A VERY VERY GOOD CHANCE OF THE OVEN/HOUSE CATCHING FIRE
Aug 07, 2011 | Frigidaire Kitchen Ranges
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kenmore Microhood 401.80089 - L SE L error
The 401 model prefix means it's actually made by Samsung.
On some Samsung models, there is an odd SE error message that seems to be vexing a lot of people.
It's probably a sensor going bad, or maybe scrambled code in the microprocessor, but it's odd.
There is one discussion of it here.
I hate to say it, but since it's a Kenmore brand, you're going to have to call Sears for service.
You can find them at http://www.sears.com
I really hope they can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | Kenmore Microwave Ovens
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Jan 04, 2008 | Samsung SMH7178STD Microwave Oven
Samsung Electric Range Oven Stove For Sale In Kentucky Ky Pick - Up Only Logo
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
