Question about Geospace Hover Soccer Deluxe Air Hockey Game
The screw won't undo
The two screws on the sides are very easy to unscrew but the last one on the bottom is too hard to unscrew, will I need to use another screw driver or can you just swap ours for another one.
Krups 8278. How to take apart
If it is EA8278 then tank out, bottom tray out, debris container on side out, drawer above it out. Unscrew 1 or 2 screws inside beans container, remove adjustment knob (clicks up and off) remove beans container. Undo two outer screws under front top flap and one screw at center back was hidden by beans container. The oblong full size bezel at the front of the machine clicks upwards to click out of its clips. Lift lid at the front and wriggle it about forcefully to unclip the rear catches. Undo 2 screws one each side at bottom that were exposed by front bezel removal and 2 screws exposed by tank removal. Rear and sides are one piece and slide back for removal. That's it, you're in.
Feb 04, 2017 | Krups Coffee Makers & Espresso Machines
Filter on washing machine
down the bottom on the right hand side is a flap,,, open it down and you will be looking at the front end of the pump,, unscrew the plastic screw type and pull it out.. if you cant pull it out after you have unscrewed it ypou will need to tilt the machine on its back and undo the one screw at the bottom near the pump, slide the whole plimpth right and it will clip off,, now undo the 3 screws around the pump,, and the pump will drop down,, you can unscrew it from its housing then empty the **** whats inside it,, then try unscrewing it once all the **** is out... then put it back together the way it came undone.
Oct 19, 2012 | Bosch Logixx WAS2446 Front Load Washer
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
It appears that the Inlet Valve is leaking on my Kenmore dishwasher. By replacing the inlet valve do I also need to undo the connection at the bottom with the teflon tape - or can I just undo the screws at...
Probably just hard water causing the solenoid to stay slightly open. Shut off water Remove 1/4 hose Remove wire harness/plug Remove other side hose should be a clamp. Unscrew mounting bracket and replace in the same order.
Hope that helps
May 11, 2011 | Dishwashers
How do i clean my tower aloha breeze fan
you have to remove the fan housing. it is usually screwed.
Sep 10, 2009 | Tower Aloha Breeze Fan
Where blinker relay on the 97 Chevy blazer and what does it look like?
It's behind the panel to the left of the cigarette lighter. You need a Torx 25 screwdriver and another screwdriver for those hex shaped screws, forgot the size.
First unscrew the 2 Torx 25 screws beneath the steering wheel. Then unscrew the rest of those Hex screws on the bottom. The panels overlap, so be prepared for a lot of unscrewing.
You do need to unscrew the middle black panel on the bottom, right beneath the cig lighter. It's held by two Hex shaped screws, one on each side and are hard to unscrew. Also you need to remove your spare change sliding tray to unscrew the last hex looking screw.
Once you pop your panel off, the turn signal flasher is the right one. The Hazard flasher is the left one. You can find a replacement part at Auto zone. It's shaped like a cylinder with TWO prongs on it.
Good luck and hope this helps
May 02, 2009 | 1997 Chevrolet Blazer
How to take off the front panel?
hI.. yOU NEED TOTAKE OUT THE SOAP DRAWER.... UNDO THE SCREWS HOLDING THE FRONT PANEL ON... TAKE THE LID OFF... UNDO THE TWO SCREWS ON TOP O THE FRONT PANEL.. UNDO THE DOOR RUBBER AND FOLD IN MACHINE... UNSCREW DOOR INTERLOCK.. AND REMOVE NOTING TERMINAL CONNECTIONS... UNSCREW THE TWO SCREWS AT BOTTOM OF PANEL, AND HEY PRESTO... IT IS OFF....!!!
BEFORE YOU START MAKE SURE THE APPLIANCE IS SWITCHED OFF AND UNPLUGGED - THIS IS VERY IMPORTANT..
Mar 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Where is the hard drive located on the think pad t20?
It is a slot on one side, held by one screw.
Unplug laptop and remove battery.
After unscrewing, slide down and then pull out the plastic cover toward the side of the laptop. You will find attached the hard disk caddy.
You will need to remove the hard disk from the caddy by undoing four screws.
Mar 27, 2009 | IBM ThinkPad T20 2647 Notebook
How do i remove the passenger side head light ?
heres how you go about removing the headlight and replacing bulbs:
you will need a 7-point star screwdriver (6+ inches)
1) unscrew the two screws on the tabs above the headlight fixture (if one is missing its not a big deal)
2) unscrew the screw on the bottom of the light fixture. It will be on the inside bottom of the light (towards the grille).
3) For the driver side: unscrew the screw that is slightly infront of the power steering reservoir (if its stuck you may need a wrench to get some movement). This screw only needs to be loosened, don't unscrew it all the way.
For the passenger side: unhook the left part of the air filter (don't worry, it pops in and out easily) there should be a screw towards the hole for the air filter on the upper left of the light, loosen it.
4) Slide the headlight fixture out of the car and undo the little metal clips over the covers. take off which ever cover holds the old bulb and replace it witht he new one. BE CAREFUL! DON;T TOUCH THE BULB WITH YOUR FINGERS, THE OIL MAY CAUSE THEM TO EXPLODE
And on the off chance you make the same mistake as me and drop the screwdrier into the engine block, park your car up on a curb and get it from below.
hope this helps!
Dec 29, 2008 | Audi A4 Cars & Trucks
Geospace Hover Soccer Deluxe Air Hockey Game Logo
59 people viewed this question
Top Geospace Sport & Outdoor - Others Experts
Are you a Geospace Sport and Outdoor - Other Expert? Answer questions, earn points and help others
