Question about DISH Network IR Remote Control
Ir remote control/dish network
My replacement remote control keeps scrolling through the search menu when I push any button to search for a show. It finally stops but not on what I want-I push another button & it does the same thing again. HELP
  • ellyho1 May 18, 2009
    I reset the system as you suggested.  It didn't help.  I'm now waiting for another remote from Dish.  Thanks for your help.
  • 374 Answers
I suggest you have Dish send you another remote as the one you have appears to faulty but if you can get to the menu sucessfully you can try to reset the system to factory defauult settings and see if that resolved the issue. Thanks for using Fix Ya.
Posted on May 18, 2009
Want to no how set remote to a polaroid tv
You must read the instruction booklet that came with your Dish network receiver or the manual that came with the remote. Try going to replacement remotes and searching for the remote control model to pull up all the info about it. If they have the manual it will show for download.
Oct 06, 2012 | DISH Network IR Remote Control
How to program a dish 3.2 IR remote to control a dish vip 722k dvr
Open the door on the receiver, and hit the menu button twice. With the remote in hand, hit sat, then record. Then use the remote to exit the menu. Voila!
Apr 07, 2012 | DISH Network IR Remote Control
I accidentally pushed the aux button last night. Now the sat button won't come on and I can't access the dish receiver with the remote.
Hi my nameis Mike Houston of DISH Network and I see you pushed the AUX button and the SATbutton will not light up. There is an easy fix to this, first replace thebatteries and try the Sat button. If the Sat button will not light up pleasereaddress the remote, I will send the link to help with these steps. http://www.dishnetwork.com/SupportSection/remote-setup
May 21, 2011 | DISH Network IR Remote Control
I pushed the dish button an the screen went black
Hello leslie_poo_1. My name is Michael Hurst with DISH Network. I see that when you press select you get a black screen. Try to perform a hard reset by unplugging the receiver from power outlet for 10 seconds then plug it back in. If you still have a black screen press the menu button on your remote. Press Menu, 6, 1, 1, select check switch and then test. Once the test is done exit out of all the menu screens.
May 06, 2010 | DISH Network IR Remote Control
Sat button won't illuminate nor operate
Hi jscot myname is Mike Houston of DISH Network and I was going over your post and thereare a couple of things we can check. The first is to replace the batteries andafter the batteries are replaced push and release the SAT button and press select.If the SAT button did not light up the remote would need to be replaced.
Dec 30, 2009 | DISH Network IR Remote Control
T.v shows channel 3, doesn't show dish sign
First ensure the receiver is connected to the TV via coaxial cable and that the receiver is powered on. If the receiver is connected via composite cables yellow/white/red you will have to change the input on the TV to match the name of the port that it is connected to on the TV. An example of this would be video 1. Some TVs do not have an input aka source button on the set itself and is only located on the original remote. Others you may need to go through the menu to access them and finally some are incorporated into the scrolling of the channels from lowest to highest etc. You may also be able to use the tv/video button on the dish remote but this is not always possible.
Thanks for using Fix Ya. I hope this assists you.
Dec 21, 2009 | DISH Network IR Remote Control
Dish Network not working all... lights up but nothing else!
call dish network. they have all the information you could possably need.
their phone number is inside your recivers manual
Aug 19, 2009 | Universal Remote Control Dish Network...
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Cannot control Vip222 with sling classic
I have read elsewhere that Slingboxes required the Dish Network receivers to be set to Primary Remote Address 1.
To try a fix:
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the Primary Remote Address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates the channel to which remote control 1 is configured.
If the Primary Remote Address of your Dish VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your slingbox remote control per the instructions in the Slingbox documentation.
Feb 05, 2009 | Sling Media Slingbox AV Remote Control
Menu button won't work
The codes that are provided to operate the tv from a Dish remote will not offer full functionality with most TV's. The menu button on the Dish remote even when able to bring up the menu screen on TV's is unable to navigate the menu screen due to the complexity of the TV's set up. The newest receiver that Dish has on the market is the 222k which is a dual tuner/two room HD receiver without DVR that has LEARNING REMOTES that might be able to accomplish the goal you are trying to obtain. I hope this answers your question and remember to keep the original TV remote in a safe place so that you can use other functions on your TV as well. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 12, 2008 | DISH Network IR Remote Control
DISH Network IR Remote Control Logo
140 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
