Question about Husqvarna Garden
Wt 255 cls weedeater
Starts,but cuts out when trigger is pressed to accelerate
5 Suggested Answers
suzukiracing
  • 200 Answers
SOURCE: johndeere c1200 weedeater
Clean air filter and check fuel lines for trash.If that isnt the problem your carb may have trash in it.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
e-Guru
  • 3917 Answers
SOURCE: MY WEEDEATER STARTS FINE ,
Hi
Remove and disassemble your carburetor and clean it thoroughly. Reassemble and adjust.
Also check this link if it helps:-
http://www.ehow.com/how_7852165_poulan-dies-throttle-trigger-released.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 19, 2011
  • 6468 Answers
SOURCE: poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Posted on Apr 08, 2012
Testimonial: "yes that worked, but i did not have to remove the muffler.. i just had to take take a small screw driver and and slide the the screen out and clean it and slide it back in. my weed eater is running like new again.. thanks"
  • 2239 Answers
SOURCE: i have a poulan 335 weedeater it is six months old it starts with choke but when you press the trigger it bogs down and stalls you can keep it running if you keep the trigger pressed but if you let of
If its only six months old i would think it is a carb adjustment issue ( running too lean ) you need to richen up the mixture by un screwing the mixture screws, start with 1/8 turn on each
Posted on Jun 30, 2012
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Husqvarna weedeater repair
Husqvarna 128 ld weedeater only runs when spark detector is hooked up. Otherwise it dies.
May 20, 2013 | Cars & Trucks
Erratic starting circular saw
Sounds to me like you have a bad cord. Clamp the saw to a workbench so that it can start and run safely without you having to hold it. Put tape or a wire tie around the trigger to hold it in. THEN plug it in. Then move the cord around, especially near where it enters the saw. If the saw starts and stops intermittently you have confirmed the bad cord. Good luck.
Mar 06, 2013 | Saws
I have a poulan 335 weedeater it is six months old it starts with choke but when you press the trigger it bogs down and stalls you can keep it running if you keep the trigger pressed but if you let off it...
Jun 30, 2012 | Poulan Garden
Poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
Apr 06, 2012 | Poulan Garden
A Part broke off from my Yardman weedeater YM4570 the part that has two parts and are held by two springs which turns and expands when accelerates
The Yard-Man YM4570 is a nice 4-cycle gas trimmer.
It's hard to tell from your description, but the part you are referring to could possibly be related to the throttle assembly:
Throttle Housing & Trigger Assembly
Part Number: 753-04234
Throttle Trigger Spring
Part Number: 791-182690
You can get the part numbers and Operators Manual at MTD Products... click here:
Operators Manual
Nov 14, 2011 | Garden
Poulan WT usually starts Ok but after it is used for 8-10 minutes it cuts out when when trigger is released. Happens mostly when you're cutting & then release trigger when cut is done.
If the carb hasn't been rebuilt in a few years, often the fuel pump diaphram gets weak or the little flap check valves get deteriorated. Carb kits are about $20.
Feb 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a miller 255 nig .the welder will start to weld and stops gas flow is working the triger is working . You can relase the triger and start it again it willweld about 1 inch and stop emall ...
Sound like you have a machine programed on stitch mode, to override the program do the following:
1)Turn off the machine
2) With the machine turned off press the gun trigger.
3) Turn on your machine keep the trigger pressed, hold it for about 3-5 seconds. Depress the trigger and you should be good.
Jan 03, 2011 | Miller Welding Tools
Johndeere c1200 weedeater
Jul 16, 2010 | Garden
Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Jul 09, 2010 | Ryobi Garden
Garden Logo
27 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
