Question about Kidde Nighthawk Combo Gas/co Detector
Alarm went off
The alarm went off and the digital reading said GAS-then flashed a code: 226. Any idea what that refers to? The gas company came over and got zero redings for explosive gas.
  • 16 more comments
  • m n Nov 20, 2007
    Keep getting code "216" for gas level!
  • m n Nov 20, 2007
    ALARM keeps going off ... GAS level....
    CODE 216!
    Please tell me what this means!
  • Anonymous Jun 01, 2008
    Our combo gas detector has gone of with readings of 297 or similar from time to time. Also had gas company check for leaks and found no problem. Are there other smells or things that can trigger the gas alarm?
  • Anonymous Jun 04, 2008
    Alarm goes off without any CO or Gas present
  • napmac Aug 04, 2008
    I experienced similar problems. The GAS alarm would go off with a reading in the 214 range, but when I pressed reset, it stopped and went back to 0. I called the gas company and they did not detect ANY gas leak. Since then I have noticed that if I spray any aerosol products in my house, the GAS alarm goes off within 15 minutes, even if the aerosol is 30 feet away. PAM spray in the kitchen, cleaning products in the bathroom, hairspray, air freshener. Apparently it is the aerosol propellant setting it off.
  • jeffstenger Aug 04, 2008
    I have same problem. alarm goes off, display says "GAS" 227
    this is a false alarm, there is no gas in house. I replaced battery and also plugged in the garage and an outlet outside and GAS alarm still goes off!
  • kayaye33 Sep 23, 2008
    Ours went off tonight with a reading of 220 and keeps going off. The fire dept. came out and tested and said it was fine. It still is going off - I had to take the battery out to get it to stop
  • Anonymous Dec 27, 2008
    My detector is going off. Flashing GAS and numbers like 248 and 242.
    I don't believe there is any gas in the house, but I can't be too sure.
  • Anonymous Jan 18, 2009
    The damn thing goes off every now and then in the 200-280 range for GAS. GAS has distinct odor and none can be detected. The furnace burns hot and bright with the hot water heater.
  • dsracic Feb 08, 2009
    My detector goes off at 247 ... have HAD Gas company here, and had my gas stove/oven checked...nothing can be found...is there anything for me to be concerned about or should I proceed with caution?
  • Anonymous Feb 15, 2009
    Mine has gone off 2 times in the last 4 hrs at 222 ppm. This is crazy am I tired from lack of sleep or is the CO taking me down? From the other posts I am assuming no danger just a common thing.
  • Anonymous Feb 21, 2009
    After I push the reset button, it doesn't alarm but indicates there was gas. It then gives a number in the mid-low 200s. Not sure what the problem is. Is this the level of Co2 that it's detected, as well as the fact that it's detected gas? Or is this the maximum level of gas it detected?
  • Anonymous Mar 04, 2009
    Happened to me. I threw it away thinking it was broken. Bought another one and same thing happened after a number of months. Will buy a different brand this time!
  • Anonymous Mar 10, 2009
    every time i spray any type of aerosol (pam, hairspray, renuzit etc) my alarm goes off, now it didn't stop so I put it inside a ziplock bag and it keeps going off non stop, I'm tired of the thing, good only for a couple months but now I hate it
  • Anonymous Mar 15, 2009
    I had the same thing. Gas alarm went off and then it showed a number of 220. I reset it and it went off again 15 minutes later. After the 3rd time it went off I called the gas company who came out and did not find any gas leaks.
  • Anonymous Apr 14, 2009
    I have had the same problem also. Keeps going off, reads 211, 212 and gas company cannot find any gas or CO. Very annoying. Anybody know of a better CO detector?
  • Anonymous Apr 21, 2009
    Occasionally gas monitor screeches and will read around 240. This usually happens after some sprays or cleaning substances have been used. My question: can these low readings under 300 be ignored, even if you can't determine use of possible causes? If someone has resolved these problems or has a solution other than tossing out my $60.00 Nighthawk combo unit please email me: pebeco@mindspring.com
  • Anonymous May 25, 2009
    My nighthawk first went off in February because of gas although no gas was dettected. its been fine since and then a few nights ago it started going off again reading gas and then a number in the 200s.
    This company should be out of business considering its co and or gas.
I just had the same problem (second time in about two months this has happened). I went to the manual, as recommended, and they had this helpful bit of information:
Q. What do the numbers mean on the digital display when
I press the “Test/Reset” button?
A. The numbers you see when you press the Test/Reset button
are NOT a CO reading or a Gas alarm. This is a simulated reading
the alarm displays as it tests its electronics. The numbers displayed
when the Test/Reset button is pushed should be between
100 to 400 (usually around 200). These numbers are shown after
the “Gas” test is complete.
Then later, they give another helpful tip...if the system does not work as described, replace it immediately. Good advice. I wonder what manufacturer I'll try this time. Repeated false alarms render these things utterly useless.
Posted on Jun 22, 2009
  • 667 Answers
You can vheck the Kidde site: http://www.kiddeus.com/utcfs/Templates/Pages/Template-46/0,8060,pageId%3D794%26siteId%3D384,00.html
Click on customer service link and you can find manuals if you don't have one. Type in model in upper right and click thr arrow. This will give you a link to your manual. If not found in the manual you can call them. Number is on site.
Posted on Mar 13, 2008
How to reset my cobra alarm without a fob after push button in cab was activated. I have code.
Go to the cobra site, trouble shooting. Never have put an alarm in. But have tore out hundreds of them. Anytime I get a No start or problems like yours. I look under the dash for after market alarms and remote starts. I would tell you up front, That system has to go. 99.5% of the time, when I take them out and fix the wiring. The cars starts and has no problems. The best alarm systems last 5 to 7 years. Cheap ones, your lucky to get a year out of them. Like I said, when I see them, they have to go before I do anything else.
Jul 28, 2016 | Ford Cars & Trucks
Hello there, I've buy zanussi fae 825 v washing mashine and now faced with problem. Mashine fill with water, then drain it off, then indicator of end of washing flashes three times, then goes out and...
First: make rapid reading of alarms
How: the appliance is in normal operating mode (e.g. while the washing programme is in operation) than:
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
The alarm is displayed by a repeated flashing sequence of the two LEDs: 1. END OF CYCLE indicator = indicates the first digit of the
alarm code (family)
2. START/PAUSE ? indicates the second digit of the alarm
code (number within the family).
After reading alarm code look down=
Could be:
E33 - Incongruence between contact closure of antiboiling and 1st
level of pressure switch.
Remedy: Pressure switch faulty; Current leakage from heating
element to ground; Heating element; Wiring faulty; Circuit
board faulty.
E35 - Water overflow.
Remedy: Water fill solenoid faulty; Leaks from pressure
switch hydraulic circuit; Pressure switch faulty; Wiring
faulty;Circuit board faulty
E36 , E37, E39 - Circuit board faulty
Dado
Jan 24, 2018 | Zanussi Washing Machines
Our Rinnai 1004FA was recently converted from LP to Natural Gas. The unit has been working fine for over a month now. Last night the Alarm started beeping and indicated a #14 Alarm. We checked the two...
As you might know error code 14 is overheat warning. My first thought was maybe the gas rates when then converted it have not been set right, this might cause an overheat. Converting these is tricky. If the vents and filters are good I canot think what else it could be.
Dec 11, 2010 | Heating & Cooling
Good Morning, My nighthawk CO detector went off with a loud continuous alarm this morning while all were sleeping. I reset it and it is not alarming now. I pushed the peak button and it reads 19. The...
When a carbon monoxide detector sends an alarm, there is cause for concern. You mentioned that the other CO detector did not go off, but maybe it is too far away to monitor the carbon monoxide levels that was in this area.
The instructions in your manual would direct you to evacuate the house immediately and ventilate. Your next step is to get a professional to inspect what may have caused the carbon monoxide leak.
A reading of 19 indicates that there is carbon monoxide in that area of your house, unless your CO detector is not working properly. Your local fire department will give you the best advice for what action to take when a carbon monoxide detector sends an alarm.
Be safe, don't assume a carbon monoxide alarm is cause by a defective CO detector, have it inspected.
Jul 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
My Atwood LP Gas Detector is sounding an alarm every 30 secs.
The alarm you are getting is telling you that the battery has nearly gone. Some gas detectors you have to renew as the crystals used to detect the gas oxydise after about five years, and are no good.
May pay you for your safety to get a new one. Try Wallmart or similar.
Aug 22, 2009 | Kitchen Appliances - Others
Flashing 12 on control Panel
This error is a Flame failure alarm.
It would be good to click HERE and print off all the alarm codes to keep.
As you've just put new gas on, you will probably have to purge the system of air before you get any gas through.
You can probably do this at the heater end.
You first need to check you are getting a spark to the pilot.
If not, check electrical connections, and trace fault to the ignition assembly.
If you are getting a pilot flame (unlikely as you're getting an alarm), you will need to concentrate on the hot-wire sensor and check if it is faulty.
Thanks for using Fixya. Please rate if this works for you.
Jul 06, 2008 | Heating & Cooling
Kidde Nighthawk Combo Gas/co Detector Logo
9,882 people viewed this question
Top Kidde Home Security Experts
Marvin
Marvin
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
