My Samsung 245B monitor now just flashes when turned on. First the screen is white, then flashes color banding red, a green, a blue, and a white in horizontal colour bands from top to bottom, the screen then turns black and the then the cycle starts over again. The menu button does not to work.
MicrowaveSvc
  • 9047 Answers
SOURCE: monitor
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
Posted on Jan 21, 2007
samkong
  • 106 Answers
SOURCE: my sansung monitor bring a lock and unlock menu on the screen
Befor replacing the Control ic please check the micro switches those could also be faulty.
Posted on Oct 07, 2007
jerryg50
  • 1667 Answers
SOURCE: Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Posted on Jun 03, 2008
var-pun
  • 331 Answers
SOURCE: Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Posted on Sep 06, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Posted on Nov 24, 2008
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
E172FP DELL MONITOR, COMES ON AND THEN GOES OFF MOMENTARILY. HAS A LOW REDISH GLOW WHILE IT IS ON.
unplug the vga cable from the back of the monitor while the poewr to the monitor is on and look for the band of colors it will move around the screen it will give red, green,blue and white color if they are the proper colors all over the screen that means the monitor is fine the problem is with the video card or the cable and, if the monitor does not gives proper color replace the monitor... any queries revertt back
Sep 17, 2009 | Dell E173FP 17" LCD Monitor
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Frozen screen with 4 band colors
Your phone is stuck in bootloader mode, it seems that you may need to reinstall your phone OS on your phone.
Go to the HTC site and download your phone's OS files/installer:
http://www.htc.com/us/SupportDownload.aspx?p_id=67&cat=2&dl_id=68
Follow the installer's instructions after you've downloaded the needed file.
Jul 19, 2009 | HTC Tilt 8900 Smartphone
Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Jun 19, 2008 | Xerox XL592DS (Silver) 19 in. Flat Panel...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
