Question about Cycling
Problems pairing Bontrager combo
When I use the Bontrager super charger pump on a Presta valve I get up to about 45lbs and it releases and deflates the tire. What I am I doing wrong here?
You are probably pushing the pump on too far before clamping it onto the valve stem, thereby keeping the valve pressed down/open. Once you reach enough pressure the pump can't hold on any more. Put it on just far enough so it clamps on the valve stem, so that the valve closes when you aren't pumping air into the tire.
Aug 19, 2017 | Bontrager Cycling
What year my bicycle is?
your best bet is to take it to a Gary Fisher or Trek dealer (Trek owns Gary Fisher, Bontrager and Klien) They should be able to quickly tell you what year it is.
Aug 15, 2014 | Gary Fisher Cycling
Bontrager node1.1 computer
Sounds like one of two things: the head unit needs to pair up with the sensor again; or the battery in the sensor is dead. Here is a manual in PDF form for the process of setting up the computer: http://media.bontrager.com/owners_manuals/computers/Bontrager_Node_1.1_+_2.1_EN.pdf
Mar 27, 2014 | Cycling
How to make a conversion on the clutch pedal of Ford XR3 1984
What do you mean a conversion of the pedal? Do you have an automatic? or do you want an Xr3i clutch?
Oct 11, 2013 | XR3 29 Team Issue Tire
The valves on my Marshall TSL 122 are getting to hot.What might be the problem? Can you get me the scheme for that amp?
Probably the bias is set wrong... Please note that when installing MATCHED pair tubes, the tube pairs usually go at opposite ends of the strings, that is one on either side of the center of a set of four.
Jul 23, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I lost my sim certificate
i tell you the problem is not much, therefore don't panic yet. but one thing, secure your sim card very well and and visit a nearby sim card provider (i.e your network) and explain to them every thing. jxt have patient and everything will still be alright with your number. Meanwhile, also pray to get it back because it is a valuable property.
Jun 14, 2009 | Mountain Trek Bontrager 24 Spoke Radial...
Constant pounding of subwoofer
Have you tried another pair of RCA's? Sounds like you have a bad pair of them.
Feb 07, 2009 | MTX RT2200 Car Audio Amplifier
Cycling Logo
67 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
