Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
Posted on May 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen goes white, flashing a folder with a question mark
My girlfriend's step-dad had connected an external hard drive to our Imac to put some files on the computer and give him some more room on the HD. The computer froze and he was unable to force quit. He decided to turn off the computer and disconnect the HD from the Imac. Ever since, when I turn on the computer, the screen goes white/blank and a folder with a question mark flashes or sometimes stays. I have tried many attempts to reboot, pressed different commands in the hopes of it rebooting. Any and all help would be greatly appreciated.
Sincerely,
Phil
  • 1 more comment
  • philhouse80 May 21, 2009
    I tried the suggestions and the computer screen still remained blank.
  • Anonymous May 24, 2009
    Our Mac is doing the same thing. So we tried rebooting while holding down the "c" button... but nothing happened...other than the blinking folder with ? showing up.. please help!
  • JDTec
    JDTec May 11, 2010
    Have you tried to plug in the external hard drive and reboot. The iMac may be looking for somethig that was put on the HD by mistake.
    Also, if you have your disk one of the installation set, boot with it. You can do so by holding the letter C down while the computer reboots. Then you can run diagnostics test. You may be able to run a repair of the OS this way.
    Let me know....
Martin Buck
Level 2:
  • Expert 86 Answers
  • Posted on May 18, 2009
Martin Buck
Expert
Level 2:
Answers
86
Questions
0
Helped
29170
Points
131
The flashing folder means that the computer can't find the boot system on the hard drive. If your girlfriend's step-dad has removed some parts of the OS, then the system will not start giving the 'flashing folder' result. You will need to re-install the OS from the system disk.
Insert the disk into the computer and it will boot from that and take you through the install procedure.
2answers
I have an external WD My Passport hard drive but Pages says it cannot create a file when I try to save a document on the external hard drive. Is it because the file format is not compatible with Imac? Can...
Apple Pages has a few bugs like this. There is a work around.
  1. Save to Desktop or Documents folder on the System Drive
  2. In Finder, move the file to your external drive.
  3. Now when you open the file from your external any saves will continue to go to your external drive.
It's a bit of a pain but works for now.
All the best
My imac will not boot up white screen with ? mark
If that ? is in a folder and flashing? That means, from my experience, that you hard drive is shot, or soon will be. I had this problem a while back. Sometimes it the hard drive would work and sometimes it wouldn't. I was lucky in that respect and got my files off my computer onto another.
If you're comfortable with this, as I don't know what sort of problems may occur... Turn your computer on and off a few times over the next hour and at least see if you can get your files out safely.
Replace your hard drive and see if it boots. If not, then you may have a motherboard problem.
2answers
Does not allow transfer of files or pictures
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
Click on the "My Computer" icon on your desktop, and open the external hard drive.
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the photographs.
usually in my documents my pictures or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my pics 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the photo file, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
2answers
Malware on external hard drive is hidding files
OK you harddrive is infected with Malware. This Malware creats shortcuts of each folder and Hide the all those your main folder.
You can scan your Hardrive with fully updated Anti Virus apllication .
To see all your original folder you can enable your Shown hidden File option from your Folder option--View--uncheck show hidden files and folder--and uncheck hide protected operating system files.
Here is the step to unhide your all files and folder in one go.
Step 1:
Click on the below link and download the file "AutorunExterminator"
http://en.kioskea.net/download/download-11613-autorun-exterminator
Extract it --> Double-click on "AutorunExterminator" --> Plug your Hard drive now.
This will remove the autorun.inf files from your flash drive and also from drives.
Step 2:
Click on "Start" -->Run --> type cmd and click on OK.
Here I assume your flash drive letter as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
You can copy the above command --> Right-click in the Command Prompt and
paste it.
Note : Don't forget to replace the letter g with your flash drive letter.
Now press "Enter".
this should solve your problem.
1helpful
I installed a second WD My Book, after the first one inexplicably filled up too quickly. Now the second one has inexplicably filled up also. What could be causing this?
The most logical reason for this problem to occur is because you're storing too many files in the ROOT of the external hard disk drive (HDD). The Windows file system can only manage a limited number of files (about 500) in the root of ANY drive. It is better to store those files in a FOLDER on the drive; Windows can manage an infinite number of files IF you store them inside a folder. Let's see if we can resolve this step-by-step:
1. Open Windows Explorer and navigate to the external HDD (drive E:, drive F:, drive G:,or whatever letter it has on your system).
2. If the external HDD does NOT have a name (such as "WDMyBook01", or something else easy to remember), RIGHT-CLICK the letter of the external HDD; Windows will give you the option of creating a NAME for the external HDD.
3. Create a name for the external HDD, you can use any combination of letters or numbers, but NOT MORE than 11 characters in length. By creating a distinct name for your external HDD, you'll have an easier time remembering which MyBook drive has certain files on it. Be sure to do this for BOTH external HDDs.
4. Next, create a new folder in the ROOT of the external HDD; give it a simple SHORT name, such as "Folder01" (no quotes).
5. MOVE ALL OF YOUR FILES from the ROOT of the external HDD into the new folder you just created.
6. In the future, put ALL your files into a folder on the external HDD, so you can avoid experiencing this problem again.
7. As you've probably already guessed, it is also a good idea to avoid putting more than 500 files into the root of ANY HDD. SOME files MUST be stored in the root, because that is where Windows expects to see them, but don't add any of YOUR files, the ones you create or download, into the root of the drive.
8. This numerical limit also applies to USB flash drives and other storage devices. You avoid this problem the same way, by creating folders in the root of the drive and storing all files inside a folder.
Good luck with this; let us know if you have any questions.
My desktop was turned off for a couple of months, and when i tried turning it on a file folder with question mark is flashing in the middle of the screen. what do i need to do?
That folder with the question mark means the computer can't find the operating system. This normally means one of two things: either your hard drive has gone bad, or your operating system has gotten corrupt, or a combination of the two. If you have the original install discs, you can boot into them and try to repair it that way- if that doesn't work, you'll most likely need to change the hard drive.
When I bought this computer used, it worked fine for a couple months, then I began to notice multi-colored vertical lines on the screen. At first, there were only a couple lines. Then slowly but surely...
sound like you have two different problems the question mark is the computer can't find the hard drive. p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
Check for a failing hard drive
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
The vertical lines is one of two thing a failing LCD module of a failing video card.
Here is how to check which one it is.
connect an external display to it.
if the lines show on the external display is a video card. Unfortunately the video card is attached the logic board and the whole logic board will need to be replaced.
If the lines don't show up on the external display the LCD module will need to be replaced.
My IMAC will not boot up
the computer nor recognize a valid system working on it,..or the hard disk is damage
2answers
Transfer all files from my old desktop to new laptop
you can do that by following the steps below;
Instructions
  1. Step 1 Connect your laptop to your desktop through a home network connection. If you have a home network, you can hook up your laptop to it via an Ethernet cable or a wireless network card. Then, you can set a folder on your desktop computer to be shared across the network. To set a folder as shared in Windows, simply right click on it, select "Sharing and security," select the "Share" tab and check the box labeled "Share this folder on the network." You will then be able to access this folder from your laptop and transfer files to your.hard drive.
  2. Step 2 Purchase a USB jump drive. These handy devices are the size of a key but can store five gigabytes of files or even more, depending on the type of USB jump drive you buy. Insert the USB jump drive into your USB port and your operating system should find it as new hardware. If a window doesn't automatically come up, you can find in your drives under "My Computer." Then, you can click and drag files into it, remove the drive and take it to your desktop computer and access the files there.
  3. Step 3 Put your files onto another external storage device, such a CD, floppy disk or external hard drive. Files are transferable between any computers as long as you can store them on something external, then use that external device to move them to the other computer.
  4. Step 4 Email files to yourself. If you only have a few files that you would like to transfer and don't have any of the equipment used in Steps 1 through 3, send yourself an email with the files attached, access your email from the other computer and download the files to your hard drive.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
