Question about Singer Stitch Sew Quick Sewing Machine
How to put thread on - Singer Stitch Sew Quick Sewing Machine
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
How do you put the thread for the needle for a singer sewing machine model 132q?
Put spool of good quality thread on the spool pin. Thread comes off spool counterclockwise. Raise your presser foot before you do the next steps: Presser foot lifted up now? Great! Pull thread tail from spool toward you and hold thread taut as you put it into first tension disk. Have that thread nice and taut? We shouldn't have any loops hanging down over the machine--okay, Keep threading all of the tension disks. You should be able to actually "feel" the thread fall into slots somewhat. Now when you get to that long silver thing with the hole in the top this is called your thread take-up lever. It should be all the way UP. Turn hand wheel- ( large round knob at end of right-hand side of machine) towards you if need be to raise it. Pull that thread taut from RIGHT to LEFT through the hole in the take-up lever. Take deep breadth here... You're almost done! Pull thread down left side of lever til you get to next disk. Put thread in small bracket located behind needle. Bring thread forward --get yourself 6" of thread-- then put it from front to the back of the eye of the needle. Are you okay? Hope I was able to help. Jimmy
Mar 31, 2012 | Singer Featherweight 132Q Mechanical...
Threading a needle
1. Turn handwheel toward you 2. Raise presser foot up 3. Pull thread from spool and pull taut under each tension disk. It's important to "feel" the "click" if you are new to threading machine 4.Make sure after all tension disks threaded that you put thread behind the slot in back of your needle. It's a little groove to hold thread securely. 5. Pull thread toward you 6. Thread needle eye front to back 7. Pick up thread under gently pull taut in front of you 8. Lower presser foot and turn handwheel toward you. A loop will form under the needle where needle thread has picked up the bobbin thread. Carefully take both threads that have made a single loop and pull toward you 9. Put threads under presser foot just lift put threads under and pull 5 -6 inches thread BACK and UNDER that presser foot Done! Hope this helps, my friend! Jimmy
Mar 30, 2012 | Sewing Machines
Top thread keeps breaking, I've re-threaded to make sure it's right, wound and re-inserted a new bobbin, checked the needle to make sure it's not bent (as described in the manual) and put it back with flat...
Not sure if you noticed but if you thread a machine with the pressure foot down it will not thread correctly. There are two little things that sorta looks like symbols for the tension on most machines. (learned this when my viking 600e kept breaking thread and I put it in shop) If you thread the machine with the pressure foot down it closes the symbol things and the thread will break as you described. If you have completed that correctly check the spool of thread. You may have a burr on the thread spool that is catching the thread that too has happened to me.
Mar 30, 2017 | Brother LS2125i Sewing Machine
I have threaded and re-threaded this machine. the threaded keeps breaking and it is driving me nuts! I have followed the threading instructions and adjusted the tensioner with no help
Do you have good quality thread? And upper and lower thread is of the same weight? Put in a new needle. Also check how you are threading the machine, put your presser foot up and pull on the top thread, it should feed smooth, then put the presser foot down, now the thread should barely move when you pull on it. You can download a copy of your machine manual for free at www.singerco.com and enlarge the diagrams to see it better.
Oct 23, 2010 | Singer 1725
Instruction on how to thread shark euro sewing machine
If you can email a picture I can help you drivewithken@blueyonder.co.uk
Mar 06, 2010 | Euro-Pro 7500XH Mechanical Sewing Machine
Hi I have threaded the machine several times and the thread keeps snapping as soon as I start sewing. I've re-threaded the bobbin and replaced the needle and it still continues to go wrong. Help!
You may still be threading the machine wrong.
Do you have the manual to look at. If you still think that everything is threaded right. Try looking at the spool of thread, on every spool there is a small slice to hold the thread when not in use. Make sure when you put the thread on the spool holder, put the slice side on first so that it is torward the back, Also when you put the spool cover on make sure it is not to big or small for the spool.
After all this;
After threading the machine and ready, before you begin to sew, lift the foot up with the lever and pull the threads from under the needle they should pull freely, if either the top or bottom thread feel tight you can tell which thread is getting caught on something. Re-check the threads.
Also make sure that the thread is going through the tension disks correctly, they go between the dsks not behind, if this machine has the down and around the tension make sure it is done right.
Hope this helps
moni
Sep 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
How do I theard the needle on the 5050C singer machine?
does the machine have a needle threader? first if so, pull it down and put the thread behind the left side of the threader and loop the thread around toward the needle then go behind the finger of the threader hold the thread back against the needle and slightly pull upwards pull the threader forward and gently let go with the right hand of the thread and the needle will pull the thread through, second if the machine doesn't have a threader, the easiest way to thread a needle is to buy a needle threader, it is a device that you put through the eye of the needle and put the thread through its hole then just pull the threader back out and the needle is threaded.
Aug 22, 2009 | Sewing Machines
Underneath stitch bad
Sometimes even though the tension is at recommeded placement, you may find with various fabrics or threads, you have to adjust it. I would try to raise the tension just a bit. Try it a little at a time until you achieve a stitch you are happy with. If adjusting the tension does not correct the problem, double check your threading. If sure it is threaded properly, especially going through the tension assembly...check your thread. I have found that the thread you use can and often does create tension problems. Try changing the thread and see if the stitch quality improves.
Mar 21, 2009 | Bernina Virtuosa 150
Thread breaka
First, make sure that you are threading the machine properly check your manual for right thread path.
Secondly, make sure you are using an embroidery needle.
Dec 13, 2007 | Baby Lock Esante
Singer Stitch Sew Quick Sewing Machine Logo
35 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
