Question about Koolatron (785169015699)
It did not cool the cans and the blue lights were flashing
Beetle blue light stays on and flashes
I had a coolant light that was always on. I was poking around and i found that the sensor for the water level the wires rusted in half
Mar 18, 2013 | Cars & Trucks
Bush IDLCD26TV16HD blue flashing light?
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Bush Industries IDLCD26TV16HD LCD TV
TV flashes blue, shuts off, and red power light flashes eight times?
either lamp is failing or cooling fans at rear blocked causing overheat
Aug 26, 2010 | Sony KP-57WS500 57" Rear Projection...
The battery indicator of my Inspiron 1420 flashes amber and blue indicating that the battery is too hot to charge. Obviously the cooling fan is stuck. can anyone help me where I can buy a replacement...
It is not obvious that the cooling fan is stuck. If the battery flashes amber, amber,amber, amber, blue then repeats, the battery has an internal failure and needs to be replaced.
The cooling fan only cools the CPU and the graphics, not the battery.
Jul 18, 2010 | Dell Inspiron 1420 Laptop
Battery light flashes blue once, orange once. Manual says battery overheated and let it cool. Been cooling for 3 1/2 hrs unplugged from anything and still nothing. No power..and blinking blue to orange...
With battery in, boot to the BIOS, check indications under battery health. I'm pretty sure it will indicate battery decline/failure which will mean, replace the battery.
Feb 10, 2010 | Dell Inspiron 1525 Notebook
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
Blue light stays on in my 2000 beetle sometimes flashes
Not certain, but you may be referring to the blue light that indicates when the water temperature in the cooling system is "cold". It's typically blue when the car first starts, then changes color when the water temperature rises. If the light remains blue the water temperature isn't heating up, and you may want to have the cooling system flushed and checked. Depending upon the cars mileage, it may be time to flush the cooling system anyway.
Jun 20, 2009 | 2000 Volkswagen Beetle
Flashing Temp indicator light, after 5 min on a cool morning
Its a Low Coolant indication. Fill the reservoir to at least the MIN level.
Jun 02, 2009 | 2002 Volkswagen Cabrio
Koolatron (785169015699) Logo
29 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Jerry Kramer
Jerry Kramer
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
