Question about north american outdoor products Shelter Logic Covered Firewood Rack 4FT
BB12590G Manual turkey frier
Looking for a Manual for Thermos turkey fryer. 009070199
This is the only one available online
07101366_oil-less fryer_English 11_20_07.cdr
pdfstream.manualsonline.com/6/678e1c72-5c28-49c1-9064-977862d9c049.pdfKeep this manual for future reference. WARNING: Failure to follow all manufacturer's instructions could ... Oil-Less Turkey Fryer installation must conform with local ...... Universal Grill Parts and Design™ is a trademark of the Thermos Company ...
Manual for Thermos turkey fryer Google Search
Nov 22, 2017 | Thermos Grilling
What temp and how long to cook a 10 lb ham in a turkey frier?
12-17 minutes per pound at 375 is recommended for an oven. I'm not sure of the difference between the frier and oven. Most prepared hams are fully cooked or smoked. Here's a link to check other info on cooking hams.
http://www.bettycrocker.com/how-to/tipslibrary/cooking-tips/how-to-cook-a-ham?utm_source=Email_newsletter&utm_medium=email&utm_campaign=BC_12_23_2016&vcode=AQAAAABFsdYhKGypebKYiGtyMEVUHdxcQGJZky68gCbk2ZRXpAh84Fo6UreMNu2noN699yr-uZMq-s5WshjGdi7heKqVYFWyADXTRxPbFUM4Wf8JXA
Dec 25, 2016 | Grilling
We have a Big Easy oil-less turkey frier & it won't stay lit. It's 37 degrees out. Would that be an issue? When valves are open, can't hear gas coming through. We've only used the propane tank one...
Yes, the outdoor temperature and any wind could play a role in it. Check to be sure that there's enough gas in the tank, to sustain the burner flames. These cookers use a lot of gas. Also, check the air intake shutter valve (where the tank hose connects to the burner). It may need adjusting to get the proper mixture of gas to air ratio. Consult your Owners Manual for the proper setting.
Hope that helps. Please let me know.
Rich
Feb 06, 2011 | Char-Broil The Big Easy 4638235S (LP)...
How long do I Fry a 11lb Turkey using a 22 Quart Electric Masterbuilt Frier
3 minutes per lb then add 5 minutes to total cook time, so approx 38 minutes.
Nov 25, 2010 | Masterbuilt 20010306 Deep Fryer
I need to know how to lite my deep frier pitco
You can download operations manual for pitco fryers at http://www.middleby.com
May 20, 2010 | Pitco Frialator 35CS Deep Fryer
I have a master built gas frier and just tried to cook a turkey and it didn't work. It took about three hours to come up to 360degrees. Put the turkey in and temp dropped to 225 and stayed there. cooked...
http://www.masterbuilt.com/manuals.aspx?search=M30BV
something is wrong if you followed the manual. I would get in touch with Masterbuilt directly
customerservice@masterbuilt.com
Phone
1.800.489.1581
706.327.5622 (local for Columbus, Georgia)
706-660-8022 (fax)
Address
Masterbuilt Mfg., Inc
1 Masterbuilt Court • Columbus, GA 31907
Nov 27, 2009 | Masterbuilt M30BV Deep Fryer
Missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Nov 26, 2009 | Kitchen Appliances - Others
Where can i get a manual for the built in filtering system for a 11 year old fryer
you can go to the maker of your frier web site and down load a manual from them they also have a parts book with all the part number printing by the part in a exploaded view so it's easy to tell what part you need. By the way the model number is usally found on the inside of the swing door of the frier on a printed badge or stamped on a plate in the same place.
Nov 02, 2009 | Pitco Frialator SG14 Deep Fryer
Instruction manual for New Braunfels Turkey Fryer
http://www.charbroil.com/Consumer/KnowledgeBase.aspx
This is the web site for a company that owned the New Braunfels Turkey Fryer. Look at the info and videos for the 'Big Easy' and the instructions are roughly the same.
Nov 22, 2007 | New Braunfels Turkey Fryer
north american outdoor products Shelter Logic Covered Firewood Rack 4FT Logo
89 people viewed this question
Top north american outdoor products Home Experts
john h
Tom Chichester
Are you a north american outdoor products Home Expert? Answer questions, earn points and help others
