Home | Dell | (E210882) Motherboard | E210882 motherboard man...
Dell Motherboard
Problem for Dell (E210882) Motherboard
E210882 motherboard manual
By jungle girl on Oct 17, 2007
I have a e210882 motherboard in a emachine h2862 computer, I am not getting any power and was looking for the motherboard manual online and have not had any success. Please direct me to where I can find the manual or offer possible solution.
Same Problem
Mar 17, 2009
-   i have same problem, power outage and when we came back i found power supply blown up coz i can smell it very burnt smell so i replaced the PS i can see the LED on MoBo but no fan no cpu turns on, so i have a feeling that i might have accidently unplugged any jumpuer type power connecter? Any ideas-   Guest
Jan 14, 2009
-   my front panel jumper doesnt match board- need manual to wire -   Guest
Nov 02, 2008
-   Same dm problem of dying mother board on my T 3985 . Only one small green light glos when it powered up. -   Guest
Oct 11, 2008
-   I was just working on an eMachines mini-tower for a friend that has this same e210882 Intel motherboard in it.  Same issue... won't power on at all, but a small green light is on, on the board itself, whenever the PC is plugged into the AC outlet.
I finally determined it was a bad motherboard, too.  Apparently, this board is prone to dying off in this manner.  (I checked the possibility of a bad power button on the case by trying to short across the pins it attached to with a small screwdriver, but that wouldn't make it power on either.)
-   Guest
Oct 03, 2008
-   Same problem. Have two of the same E-machine computers. Both have the same e210882 boards, one works the other does not. swapped ps from good one but still only get green led on board. I'm guessing corrupt board. What chipset is it? So I can replace with different manufacturer.-   ninedaleys
Best Solution
posted on Sep 20, 2008
Very Helpful)
xms2000659
Rank: Apprentice
Rating: 98%, 3 votes
Ok, so the fix I found was to cut to the chase and replace the Main Board. I tryed everything and the PS, HD & CD / DVD drives, PCI cards, memory, power switch, cabling, virtually everything was fine except the Main Board. I wouldn't promote any particular seller but I found a replacement, new in box, upgrade MB by FOXCONN on eBay and the model I opted for was a 661MXPlus but there may be other options that I would have preferred such as a SATA drive controller built-in. This model had an 10/100M lan, USB 2.0, 6 channel audio and AGP 8x built-in but the same IDE controller. It fit the case with a separate back panel for the new plug configuration and worked fine. The website is www.foxconnchannel.com. Good Luck.
Comments:
Sep 21, 2008
- How are you going to download firmware if the PC won't boot or even try to power up? Replaced the PS with a good one and the one from the problem PC worked fine in another PC. Only have a green LED on the MB that lights?
Thx for Trying!
Was this helpful?
Yes
No
Solution #2
posted on Oct 31, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
check on DELL computers site /  thier version is the OPTIPLEX 210L.
sounds like the power supply went south, or there is a peripheral pci card, or module shorting out thr power supply. try this after documenting the hardware configurations you could pull components one at a time and check to see if it powers up. if it is the supply you can use a standard atx power supply that supports the 24 pin motherboard interface and the 4pin pci bus power connector. good luck
Solution #3
posted on Jun 21, 2008
Helpful)
ghrussellman
Rank: Apprentice
Rating: 86%, 3 votes
download intel active monitor from intel. run it. on ifo tab ->
it will tell you your motherboard's modle number. The
goolge.com .
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Sep 21, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
these boards use firmware...if it is corrupted or out of date for any reason system failures will happen. download the firmware and it will recon all affected pathways. for no power issues, replace the power supply with the next highest watt and do not restart or turn off until firmware is installed or downloaded.
Solution #5
posted on Nov 21, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Have you checked the power switch? Friend of mine was having the same problem and after several hours of swapping m/b's and power supplies we hooked up a power switch from a different case and the power came on without any problem.
Solution #6
posted on Sep 23, 2008
Very Helpful)
ElderEd
Rank: Apprentice
Rating: 100%, 2 votes
for skwertos: Pwr on/off switch connection on MB is J9G1 pins 6 & 8877413
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #7
posted on Oct 11, 2008
Somewhat Helpful)
velut_umbra
Rank: Wiz
Rating: 81%, 66 votes
This usually works to determine if the board is the guilty one, when everything else seems to be ok:
Unplug the power cord, remove all hardware, keeping the needed things: CPU, RAM and VGA card. Then, short the MB´s power switch pins for a few seconds. This will unload the capacitors on most devices. Replug power and try to boot up. After that, add all your hardware, one piece at a time, and booting everytime to see if it turns up.
REMEBER TO UNPLUG POWER CORD BEFORE REMOVING OR ADDING HARDWARE. Though its only 12 and 5 volts inside, 300watts is enough juice to make you aware of it.
If you find the part that locks your system, remove-it, do the capacitor unload procedure, and keep adding the remaning parts using the same method. I found that most times, the floppy is the guilty one, because it tends to overload when there are power surges, even if the surge does not shutdown immediatly.
Was this helpful?
Yes
No
Solution #8
posted on Oct 26, 2009
Not Rated)
meismale
Rank: Apprentice
Rating: 0%, 0 votes
E-Machine T2862. I need to know where to plug 1) green and white labeled POWER LED
2)black and white labeled POWER SW
3)red and white labeled H.D.D LED on motherboard
Was this helpful?
Yes
No
Solution #9
posted on Jul 06, 2009
Not Rated)
techsurprise
Rank: Apprentice
Rating: 0%, 0 votes
I have seen these problems with almost every E210882 motherboard that comes through my shop. It turns out that there is a problem with the power supply, which in turn is damaging the motherboard and cpu. After talking with Intel and Dell, they are recommending replacing all three parts. Typically the motherboard will be replaced with a different board, so there is most likely at the very least an operating system repair process, at the most an operating system load involved. Good luck!
Was this helpful?
Yes
No
Solution #10
posted on Dec 16, 2008
Not Rated)
robertosolru
Rank: Apprentice
Rating: 0%, 0 votes
how i can get the manual of the motherboard E210882
Was this helpful?
Yes
No
Solution #11
posted on Nov 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Guys its the actual power button jump the pins and see for yourself...
Solution #12
posted on Oct 31, 2008
Not Rated)
springs387
Rank: Apprentice
Rating: 0%, 0 votes
Kindly E-Mail me the D865GBF or E210882 Manual
Regards
Stephan du Toit - Cell: 072 807 8845
stephanosa@telkomsa.net OR springs@kbconsulting.co.za
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (E210882) Motherboard?
Answer
Answer
VIA vt82c693a motherboard cant find ide hdd in award bios gui checking and couldnt boot but if i... (More)
Answer
my optiplex gx240 suddenly wont hold bios settings. changed the board battery...no joy. confused!
Answer
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,... (More)
Answer
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard... (More)
Answer
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan... (More)
14 Other Users Have The Same Problem - Continued
Comment by SASMOTAZ, posted on Oct 01, 2008
I HAVE THE SAME PROBLEM, ALL POWER SUPPLY GOOD, MONITOR LIGHT GOES ON BUT WHEN I PUSH IN THE BUTTON TO TURN ON THE TOWER, IT DOES NOTHING(THERE WAS NO POWER OUTAGE OR LIGHTING STRIKES)
Comment by ElderEd, posted on Sep 23, 2008
Lost power to residence for several hours. When power returned, the PC (Emachine T2824 with Intel MoBo: E210882) will not power up. LED on Mobo does light up when pwr cord is connected to PS, but pwr on button does nothing. Replaced P.S. but symptoms do not change. Metered pwr on switch...OK. Shorted MoBo pins J9G1 6&8 (pwr on) with no result.
Comment by SlappinDpoo, posted on Sep 04, 2008
No power. LED light comes on once power cord connected. The mother board led and on/off power switch connected correctly. New power supply in. Nothing. I think mother Board is dead.
Comment by skwertos, posted on Aug 30, 2008
I need find power switch to connect the power switch
Comment by xms2000659, posted on Aug 19, 2008
I have a simular problem, after a lightning strike to tree in yard. Unit was disconnected from power but still connected to DSL line. Green led on motherboard is lit now but all power off to drives. Pressing power button has no effect. Replaced power supply and unplugged all cards w/ no change. Power supply, Hardrive and DVD drive were OK as were PCI cards; tested by installing in another E210882 system. No obvious signs of blown chips or burnt circuit board anywhere. Unit will not even try to start?
Comment by Guest, posted on Aug 02, 2008
need manual for E210882 motherboard
Comment by Guest, posted on Jun 29, 2008
i have disconnected the led wires and can not reconnct them
Comment by Guest, posted on Apr 29, 2008
After having a power outage, I only a green light on the motherboard. No other functions are on, all fans are off including the processor cooling fan and interior case fan. I did an ohm test on the power switch which was ok only when I held the switch in. When I release the switch I lose continuity.
Comment by Guest, posted on Nov 16, 2007
i DO NOT GET POWER FOR DELL E210882
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14685
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
