Question about Sony DAV-C700 System
The DVD an CD doesn't work
When I put the CD into the unit, this start to work, and the sound apear for a few seconds, but inmediatly the system turn in off, and apear the word PROTECT
  • 10,594 Answers
Check speaker connections and wires and make sure all wires are plugged properly. If problem still exist then unplug speaker one=by-one and test home theater to determine what speaker is causing Protect error.
Posted on May 17, 2009
Unit turn off inmediatly after turning it on
There is a low freon pressure switch in the system. A small amount of freon will show enough pressure to start the unit. As soon as the compressor starts the low side pressure (where the switch is) drops and shuts the unit off.
Nov 05, 2014 | Maytag Heating & Cooling
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
Feb 02, 2013 | Dell Vostro A860 Notebook
Doesn't load the disk
Someone needs to open it to SEE what is happening--if the unit holds more than one disc (model seems to indicate that) you likely have a mechanism problem with something jammed or even broken--mechanism could also be out of alignment which is a task for a pro.
Look and see what is happening is first thing needed here.
Apr 24, 2012 | Cyberhome CH-DVD 300 DVD Player
My new toshiba tv had sound but no picture. Only a few seconds (2)still image but inmediatly turns off an only audio hears. Not displays any other function, Menu or any else.
Hi, Try to play a DVD movie. If there is still no picture then you know the tuner is no good. I would take it back and ask for a replacement TV. (warrenty is still good).Good luck.
Aug 01, 2011 | Televison & Video
Does not recognize any cds
Insert a CD that has writing on the top, noting which way the lettering is facing. Close the drawer. Wait a few seconds. Open the drawer.
If the lettering still is facing the same way, the disk did not "spin".
So, the motor that spins the disk is dead. Replace the CD/DVD unit.
If the disk does spin, then the laser inside the unit has failed. Replace the CD/DVD unit.
Sep 10, 2009 | Computers & Internet
I have a Rio HT2030 Home Theater manufactured by Sonic/blue. When I placed a DVD in to play, I received an error message, could not read. I put in a CD in the same unit, and it played the music CD. I know...
did you try 2 or more dvd's
if that does not work the motor that spins the cd/dvd is faulty.it can also be the lazer so try other dvd and the see what happens
May 11, 2009 | Televison & Video
I have the eclipse avn 5495, the unit doesn't power up
sometimes when i start my car there is no sound. all of the options (radio, cd, dvd) seem to be working and i can switch between them, however there is no sound. i have to turn off the car and let it sit for a few min. once that is done, i get sound again. is there a reboot option while the system is powered? and what else is there to check?
Mar 07, 2009 | Eclipse AVN5495 Car DVD Player
Acer TravelMate 290 PC Notebook not starting
I believe these are BIOS indicators on some type of motherboards This could be a motherboard or memory problem. What happens if you remove some or all memory?
Sep 24, 2007 | Acer TravelMate 290 Notebook
Won't start up
First, try re-initializing the main unit: While stopped and ?DVD/CD? is the source, press and hold STOP (the small solid square on the unit AND [>10] on the remote control until ?Initialized? disappears from the television. Turn the unit off, unplug it, and turn it on again. Make sure that cd mode is off by Pressing [SHIFT]+[CD MODE] and try your DVD player again. (Make sure your discs are clean, and try several to make sure that is not the problem) Let us know how it works for you, and if we can help you in any other way. Best regards, nightdiver
Jul 23, 2006 | Panasonic SC-HT730 System
Sony DAV-C700 System Logo
141 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
