Question about GE PVM2070SMSS Microwave Oven
Touch screen not responding
When I open the door the display comes on the touch screen but touching the screen does nothing. The fan works but nothing on the touch screen does.
5 Suggested Answers
SOURCE: touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Posted on Jun 11, 2009
  • 57 Answers
SOURCE: I have ge spacesvaer over
It sounds like your door switches are not working right. If out of warranty it would probably be cheaper to replace the unit.
Posted on Jun 03, 2011
  • 65 Answers
SOURCE: Touch screen displays is lit
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Posted on Oct 01, 2011
SOURCE: GE model JVM2070SK02 touch pad not working
Most people, and GE will tell you these are not repairable and you must replace the whole unit for $300 - 500. I can fix them. If you are interested, let me know. em.ka.ventures@gmail.com I can only fix the touchpad not working and it must not be physically damaged. You must be able to take out the control panel and send it to me. It is easy (3 screws and electrical connectors).
Posted on Jun 19, 2012
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
GE, Model# PVM2070SM1SS microwave - touch panel does not respond
GE has a special program, and your microwave is very likely a part of this program. Please contact GE consumer relations asap at 800-386-1215, at the prompt press 5. Our same microwave model has that problem. GE is replacing the entire microwave free of charge.
Jun 21, 2012 | GE PVM2070SMSS Microwave Oven
Whirlpool GH6177XPS3 Touch Error display
I've got the same problem and error code. Did you ever find the fix?
Jul 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Touch pad doesn't work
Mar 15, 2009 | GE Profile Spacemaker Over-the-Range...
Spacemaker 2.0 was set to warm coffee. Before warming finished, door was opened. After door was clossed screen remains showing "Coffee" but screen does not respond to any touch.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Mar 17, 2008 | Microwave Ovens
Microwave came on by itself
Yes this is usually caused by the touch assy, but $278 !!!!! Thats kinda steep considering the panel assy is only around 30-60 bucks!!! It will need the touch assy and even possibly the control board, because sometimes the logic IC gets fried and causes "ghost issues" as well.
Sep 17, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE PVM2070SMSS Microwave Oven Logo
20 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
