Question about Genius GX Gaming SW-G2.1 1250 - 38W 2.1 Channel Gaming Speaker System, Wooden Cabinet Subwoofer with Rich and Deep Bass
Gx gaming speakers no sound out of the box
Installed the speakers correctly out of the box to my pc and set up correctly in windows 7 but can get no sound
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: i have sound card genuis (sound maker 5.1) and i
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Jun 17, 2011
No sound
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 18, 2013 | HP Compaq DC5800 Small Form Factor PC...
Lost sound after installing windows 7 on my hp d530 sff pc
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps.
Jan 02, 2013 | HP Compaq d530 SFF PC Desktop
No audio gt5622 windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
hope this helps
Aug 31, 2012 | Gateway GT5622 PC Desktop
How can install audio in my pc mercurypvm7
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Jun 25, 2012 | Mercury P4VM800M7 Motherboard
No sound from my speakers after i pluged the into a dell desktop
Look for speaker icon in task area (right side of task bar). If there is a red x on it it means the speakers are muted or the sound device drivers are not loaded or the sound device is disabled. Click on speaker icon and go to mixer. Check for muting. If it says sound device is not present then open Control Panel by clicking on Start or Windows button in lower left corner, go to Control panel, often abbreviated "CP" then click on system then on device manager and see if Sound, video and game controllers has an audio device listed. If not you'll have to acquire the drivers from the dell driver download site and apply them. If it does and device shows disabled, then click on it and enable it. If there is no sound device then check for an "Other device" entry in device manager. It'll usually have a yellow ! on it. That means a device was identified by plug and play but the system could not find a driver for it. Go to windows update service in CP and run find updates. If Windows finds an upated sound driver, install it. It will install and plug and play and set up device. Otherwise off to www.dell.com with the service tag number of the computer---found on back or top of system. This will lead to the downloads and drivers page for your specific box. Look down list for Sound drivers, download and install them. Usually with dell it downloads as an executable (Rnnnnnn.exe) and all you have to do it click on the file name to run and install it. After download If in Vista or Windows 7 I always right click on file name and chose "Run as administrator" whenever installing like that. That makes sure you have adequate permissions to do the install and have to install correctly.
Also it goes without saying to make sure you have plugged the audio in lead to speaker set into the correct sound plug on back plane of system (usually the green one).
Feb 20, 2012 | Boston Acoustics BA735 Computer Speakers
My altec lansing bx1020 is not working after i upgraded my pc to windows 7.
The problem is not with your speakers.
When you upgrade to a new Operating System, sometimes your hardware is not recognized correctly by the new OS.
In your computer, the sound card is not installed correctly. Search for Windows 7 sound drivers for your sound card and install.
If you think the problem is with your speakers, you can check by connecting them to another computer or an audio device.
Sep 11, 2011 | Altec Lansing BX1020 Computer Speakers
Intel(R) Desktop Board D945GCL,Window 7 ultimate is installed.After installing Audio Driver (Version 5.10.5208.0) Sigma High Defination Codec,in speaker properties,Jack is showing Jack information not...
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Aug 19, 2011 | Intel D945GCL Motherboard
I had ASUS P4VP-MX motherboard. I had installed windows 7. My problen is that Audio driver is not installed. I am fagde up that i did not get audio driver from web site, pl help me
from my experience you can use windows xp audio driver as windows 7 audio driver, just install the windows xp audio driver and you will get the driver for your windows 7
Feb 24, 2011 | ASUS P4VP-MX Motherboard
Plz help me to install a sound card driver in window 7
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 29, 2011 | Intel inside Pentium 4 P4 System Case...
I just installed windows 7 32 bit in my acer travelmate 4222, everything is fine except for sound. there is no sound in speakers but sound from headphone jack is coming. i checked acer's site but there...
Hello
If the sound is coming from headphone jack then its mean that the drivers and windows installed correctly, you may check the speakers and speakers connection of your laptop. the speaker jack may be loosen or speakers may gone faulty.
Hope this helps, if so do rate the solution
Jan 05, 2011 | Acer TravelMate 4222WLMi Notebook
Genius GX Gaming SW-G2.1 1250 - 38W 2.1 Channel Gaming Speaker System, Wooden Cabinet Subwoofer with Rich and Deep Bass Logo
143 people viewed this question
Top Genius Audio Players & Recorders Experts
ptpumpman
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Genius Audio Player and Recorder Expert? Answer questions, earn points and help others
