Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Model # ws65813 how to self diagnostic please
Same blinking light won't turn on WS65813my tv works with sound and video but locks up and resets with blinking green light when i try to change input devices. repairman came when it did this before but it was still under warranty. he entered a cmos reset code using the remote. i wasn't here when he did it or i would have written it down. ever heard of this and what the code is?
  • 6,784 Answers
Hi. This cmos code is an RCA deferment procedure that is used to bypass the stand by mode when the main board is experiencing IC failure. this is just prolonging the inevitable. This code is an in House RCA plant and we have no way of retrieving this for you at this time. I can tell you what the issue is and how you can fix this.
This is a main board/signal IC(Integrated Chip) issue. The input chips that regulate the input direction that is streamed threw the signal board and threw the deflection yoke, is malfunctioning and overheating as well. this will cause the TV to go into stand by mode and shut down. Simply replacing the affected boards will fix this issue.
Main Board--Mitsubishi Part Number: 930B903004---$259.95
Signal Board--
930B905001-48---$282.95
Posted on May 17, 2009
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
Contstant blinking green light on Mitsubishi ws65813 projection tv
u have bad dm board , this board look like a cable box , when u open the back cover of ur tv u would see this box , u have to replace about 7 capaciotors on this box , the capaciotor are on the small boars inside on this box 1000Uf at 16 volts , but if u have no idea on how to replace this cap u can hire a tv tech nowmal repair is about $250
Nov 02, 2010 | Mitsubishi Televison & Video
Blinking green light on mitsubishi ws65813 tv i replacec the capicators but last time a tech had to replace a fuse too. where is the fuse?
On the power supply board near the connectors for outputs. Probably a 'pico' fuse which is small and soldered in - looks like a solid colored smaller resistor, usually.
Apr 11, 2010 | Televison & Video
Green light flashing
The WS65813 is the V23++ series. The blinking led means the DM caps have failed you can get the V23 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures so you can do the repair. Heres the link its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Feb 16, 2009 | Mitsubishi WS-65813 65" Rear Projection...
Mitusbishi WS65813 blinking green light
You have a defective power supply and/or DM board, usualy are bad caps 1000 uf 16v, if after replacing all caps the problem persist you will need to contact mistsubishi and send the chassis for repair.
Jan 16, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS65813 Rear Projection TV. Main power board is bad,
they are no longer available from mitsubishi or the distributors. You may be able to get the board remanufactured at the following link. Just leave them a email with the part number.
Aug 31, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Ws65813
Check threads for DM repair or ctechnicians.com
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws65813
HACKER-PROBABLY BAD CONVERGENCE AMP IC CHIPS,TEST AND SEE IF YOUR CONVERGENCE FUNCTION IN YOUR MENU WILL WORK,IF NOT CHANGE THE 2 STK CHIPS INSIDE TV.IF YOUR NOT A GOOD REPAIR GEEK I,D CALL ATV GUY OUT,EST.AROUND 300.00. JOE TV
Dec 12, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
