Question about IBM ThinkPad T22 2647 Notebook
My IBM thinkpad is not working
When I turn on my think pad, my screen goes blank? what is the problem?
  • Manthor329 May 11, 2010
    So, it goes blank and nothing else? Have you done any upgrages to it?
  • IBM Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 18, 2009
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
Blue screen help
Try doing this
1. Boot to your windows XP cd
2. On the welcome to setup screen press "R" to go to recovery console
3. It might ask to select a drive to letter something like that just choose the number represent "x:/windows" then press enter
4. If it asks for admin password just press enter (most system has a blank password for admin user as a default)
5. Type "chkdsk /r /p" on the command prompt
6. This might take 1-2 hours depending on your computer.
Hope this helps...
Jun 10, 2009 | IBM ThinkPad T23 2647 Notebook
My think pad goes dark after the windows logo...
Right click on te screen and click on properity in the screensaver tab check the power setting to make sure it is not set to hibernate if so un check the boxs and check the shutdown time
Apr 21, 2009 | IBM ThinkPad T20 2647 Notebook
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Locked screen
I found a page with a video, on how to open a padlock - I hope this is what you need, it looks easy.
3325d60.png plz let me know how you go - maybe I know of a safe we colud open...
/Teis
Jan 16, 2009 | IBM ThinkPad T20 2647 Notebook
When i turn on my laptop, the screen is blank
It seems to be u have problem with ur RAM ..Try to change it
Nov 29, 2008 | IBM ThinkPad R40 2722 Notebook
T41 IBM thinkpad monitor goes off
Saw exactly the same think on another t41 i was trying to fix. If it was moved at all screen went off.
Turned out it was corrosion on the motherboard that was causing the problem.
Has it been liquid damaged or got damp in the past?
Jan 07, 2008 | IBM ThinkPad T41 Notebook
ATI Graphics card
Try downloading new driver for the card from this link
http://ati.amd.com/support/driver.html
Oct 16, 2007 | IBM ThinkPad R32 2658 Notebook
IBM ThinkPad T22 2647 Notebook Logo
145 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
