Question about Acer Aspire 5520-5908 Notebook
Low memory slow running video/audio programs host process stop working
My acer 5520-5334 keeps telling me that my computer is low on memory so it then tells me to change my virtual memory to the recommend setting. i do so but my computer still is running slow when i am running music or video programs the picture and sound doesn't match up or the sound for my studio software drags what can i do to fix this problem should i just add more memory and if so what kind? also i cant update my computer it just won't download all the way then i get host process for windows services stopped working and was closed what is that?
  • Acer Master
  • 19,396 Answers
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Posted on May 21, 2009
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Memory problems
  • Install more RAM
Mar 08, 2013 | Dell VOSTRO 3350
Youtube keeps stalling, plays for 20secs then just stops?
YouTube freeze can happen due to many reasons. Major reasons are overload on website, simultaneous running of many programs on your computer, Low RAM, Slow internet connection or corrupt windows registry.
For smooth watching of YouTube Videos take following actions:
1. Watch videos at off peak times, if possible
2. Do not run other programs while watching videos. They slow down computer in general by making use of memory.
3. Add RAM on your computer. More RAM will make easy execution of heavy programs on your system.
4. Get better and speedy internet connection. Talk to your ISP in this regard.
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reginout cleaner and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Jan 19, 2011 | YouTube Videos
Why do my videos start and stop
slow internet connection speed or not enough memory. you could have to much running at the same time but if not the above should be the case.
Dec 26, 2010 | Computers & Internet
My utube keeps freezing while watching my line dancing videos its stops during the dance.
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reg in out and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Nov 30, 2010 | YouTube Videos
Youtube will start & stop, it never plays a full video
try to use any other browser. YouTube freeze can happen due to many reasons. Major reasons are overload on website, simultaneous running of many programs on your computer, Low RAM, Slow internet connection or corrupt windows registry.
For smooth watching of YouTube Videos take following actions: 1. Watch videos at off peak times, if possible
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reginout and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Oct 14, 2010 | YouTube Videos
When go on line computer freezes
check your memory and processing speed. if you have a low ram and bad speed you will face this problem.
run a defragmentation on your system and clean your system by running virus scan on the system. and also uninstall unnecessary programs that you think that slows the system and ans diable all the automatic live updates and firewall that is causing the system slow when you trying go online.
thank you
May 19, 2010 | Acer Aspire 5100-5022 Notebook
Videos pause alot i cant watch a full video straight through and computer running a little slow. My base score is 3.0 and lowest score is video card. I am using a Acer Aspire 5515 with windows vista.
Performance problems are caused mainly by two things: low memory and data fragmentation on your hard drive. If you're running a late version of Windows (Vista or 7RC), on only 1GB of RAM you're bound to run slowly.
Keeping the laptop on sleep or hibernate mode for several days, or weeks at a time, cause garbage left by improperly written software to exhaust your available memory, no matter how much you have.
The simple fix is to restart your laptop every other day or so. This is good both for your sanity and your laptop, and clears up any garbage in your memory.
If you're experiencing the problem when watching a DVD, then the problem is most likely caused by the shortage of memory. You can also help by closing any programs and stopping any unused services from your Services window, to reduce memory use.
The next cause can be fixed two ways:
1) The least expensive one is to run Disk Defragmenter, from Start->Accessories->System Tools. It's not very sofisticated as other tools, but it does the job.
2) Buy special software to maintain your data defragmented, such as Norton System Works.
If you're running Symantec 360 or similar software, you have a better tool here. Check the program Help for ways to run Disk Optimization automatically and effectively.
Regarding your video card score, it's a concern, but it should not be the reason for the hic ups you're experiencing. Downloaded movie files are rather large, and should be written all at once, and alone, when data is least fragmented, to ensure one clean smooth stream from your hard drive during playback.
Aug 21, 2009 | Acer Aspire 5720-6661 Notebook PC
I need solution for windows host process (rundii32) has stopped working.
If its called rundii32 and not rundll32 then you have malware run this program its free and really good.
http://www.malwarebytes.org/mbam.php
Cheers
May 06, 2009 | Dell Computers & Internet
Media Stuttering
Run your disk defrag after taking off your files. Also, get more ram so the machine doesn't use the hard drive for virtual memory as much.
Jan 01, 2008 | Acer TravelMate 8204WLMi Notebook
Acer Aspire 5520-5908 Notebook Logo
537 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
