Question about Skullcandy SLYR Gaming Headset - Black/Yellow
Problem with microphone
HI - I've just bought a headset and I have connected it to my pc with the audio cable but I can't get the microphone to work. Please help!
Philips SHG7980 microphone problem
Go to Tools...Options...Audio Settings and try choosing different choices for Microphone.
Jan 18, 2014 | Philips PC GAMING HEADSET BLACK/RED...
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
Sennheiser md 42 microphone not being picked up on camcorder help please.
This would require a special cable to work. The mic is MONOAURAL with BALANCED output and the camera is STEREO input. This means a special cable is needed and you would probably have to make it yourself as I haven't seen one on the market.Pin 2 of the XLR of the mic would go to BOTH the tip and ring of the plug into the camera. Both pins 1 and 3 of the XLR at the mic would tie to the sleeve of the plug to the camera. If you tried an XLR to 1/8 adapter, no audio would be heard other than from the buillt in mic.
Mar 08, 2013 | Sennheiser MD 42 Professional Microphone
Hi there, I've just bought an Acer notebook ASPIRE 5750, windows 7 home office. Everything is ok, but softwares like speech recognition, skype and google talk, don't recognize my microphone...
You may have to disable the onboard microphone to use the connected hardware.
Realtek is very picky, same goes with speakers connected to the back and front at the same time, no sound. Disable the one you are not using.
Sep 05, 2011 | Acer Aspire One PC Notebook
Where do I plug in the microphone/headset
The green jack from your headset has to be connected at the rear panel of the monitor, just beside the VGA cable. This is for feeding the audio to your headphones. For more details take a look at this picture:
The red (orange) jack from your headset (this one is for the microphone) has to be connected at the back of the pc tower, at the red jack, marked as microphone input. In case you need to extend this jack you may use an extension cable like this. In case you don't need the microphone option (if for example you need just the headphones from the set in order to hear audio, movies e.t.c.) you don't need to connect the microphone jack.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 23, 2010 | HP vs15 15"LCD Flat Panel Monitor
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Oct 15, 2009 | M-Audio Luna Professional Microphone
Microphone in Ventrilo is too low
try on another pc in sound recorder if working there then the headset is not the problem. try uninstalling the sound card and rebooting the pc.
may correct the issue.
Dec 29, 2008 | Logitech ClearChat Stereo Headset Headset
I just bought a GE Portable headset with detachable MIC
I had the same problem, but fixed it. All you have to do is:
(I have a Dell Laptop)
1. Go to the control panel
2. Go to the sounds, speech and audio devices
3. You are supposed to see the icon that belongs to your sound card (Mine is SigmaTel Audio), click on it
4. Activate the port where the microphone is connected, close
5. Configure your microphone as you normally would
6. It should work
Oct 10, 2008 | GE (JASHO97748) (3 Pack) Headset
External Microphone - Not working
good day
have you tried inserting the microphone plug to the red/pink socket in your sound card?
Sep 20, 2008 | Compaq Presario 700 470024-192 Notebook
Philips webcam and headset
try the back of the computer..there should be three colored inlets, one of them green
Feb 27, 2008 | Dell Dimension 1100 PC Desktop
Skullcandy SLYR Gaming Headset - Black/Yellow Logo
20 people viewed this question
Top Skullcandy Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Skullcandy Radio Communication Expert? Answer questions, earn points and help others
