Question about Video Game Consoles & Games
Retro duo portable won't work
My rep says it's charging, but when I go to play it turns on for a few seconds and shuts down. The green light indicating it is charging is present
eagle338
  • 4889 Answers
SOURCE: psp battery won't charge
Its a problem with the unit's charging pins..you will have to get it replaced it shouldn't cost you more than 10$..
Posted on Oct 27, 2007
  • 3 Answers
SOURCE: need help to hook up my nintendo retro duo to t.v.
In the cords & cables that came with your system, there should be one cable that has a place for cable ready tv and one for non cable ready tv. The non cable ready looks like the 2 wires that run from a tv antenna. If you have a cable ready tv you just use the screw on part like on a vcr. Also on the back of most newer tvs you will find what they call rca type plug ins. You can use them to connect it also. They are simple just follow the color codes such as white to white and so forth. There should have been an instruction sheet to show you this. I have noticed that depending on when it was built/shipped they have some that are shipping with the rca cables. If your tv is an older one and doesn't have the rca jacks in the back of it you have 2 choices that I can think of well maybe 3.You can upgrade the tv or you can buy a box designed to convert the older tvs to use the rca jacks or and most likely the simplest plug the rca cables into the back of a vcr.The last suggestion will not require the vcr to be turned on. It will work on a simple pass through. The vcr will work as normal with all other functions it has and it gives you the option of recording you playing the game so you can prove the levels you made and also show you mistakes you made in losing the game. I hope this helps I tried to keep it as simple as I could for all to understand. So please don't think I was trying to talk down to or above the head of anyone.
Posted on Jan 04, 2009
praky16
  • 744 Answers
SOURCE: Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Posted on Jul 20, 2009
dehnn08
  • 13 Answers
SOURCE: my PSP shuts down by itself
go to a technician.....
they know what to do on ur problem..
Posted on Sep 06, 2009
SOURCE: Both my FC Twin and Retro Duo (brand new) have issues with nes...
If it's a flat screen especially, there will be major resolution problems. I know the laser gun doesn't work at all on flat screens and some newer TVs. You gotta play NES on an old school TV any way. It makes the experience much more authentic.
Posted on Nov 19, 2009
I have a retro duo portable v2.0. Whenever I play a game on it, there is a little green light that always flashes. I have to assume this isn't normal because it's a major flaw if so. The light will still...
You don't say how old the battery is, but if you have had the device for more than a couple of years and the battery is original it may be time for replacement.
Nov 13, 2013 | Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Aspire ahows green light but won't start up, have turned off main but still just green shows
Pull the plug from the AC outlet, wait a 30 seconds, plug in, try to reboot. Does it try to start and in a few seconds shut down? Give as much detail as you can.
Dec 19, 2012 | Acer Aspire™ T135 PC Desktop
My NDS just shuts down randomly in the midst of playing, usually with the green light giving a few blinks. No flashing screens though, and it's definitely charged. What could be wrong?
Is it still under warranty? Call Nintendo and have them repair it for you. I had the same exact issue, Nintendo solved my problem in less than a week.
Jan 07, 2012 | Nintendo DS Console
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
Psp power up green lights on black screen after a few seconds shuts down psp slim
it sounds like you bricked you psp, if it's not a 3000 or psp go you can probably fix it by buying a pandora battery and magic memory stick.  you can buy them from here http://pandorasales.com/?gclid=CNLk1fzUzqgCFcO8KgodAzI2lA , if you are running a psp 3000 and up, you could try to format your memory stick but it probably won't work.
Apr 25, 2011 | Sony PlayStation Portable (PSP) Console
When I plug the charger into my macbook pro "intel duo" the charger light is green, but turns oranges after several seconds
it means its charging hte battery , when it turns green again it means its completly charged , hope this helps in some way.
Dec 03, 2009 | Apple MacBook Pro Laptop Computer with...
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Video Game Consoles & Games Logo
13 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
