Question about Capresso Jura-Impressa C9 One Touch Espresso Machine
Clogged nozzle - Capresso Jura-Impressa C9 One Touch Espresso Machine
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Try poking something in the hole of the brother. I usually bend out a paper clip and use it. After clean the machine with vinegar.
Posted on Aug 23, 2015
Washer pump won't spray , got current to new pump
Jerry. You said youcleaned the hoses? Did you also clean the sprayer ports? They maybe clogged. When i had this problem I used my air compressor and blew air through the hose and ports. This solved the problem. Lastly did you check to see if the tube running from the washer tank is not clogged?
Feb 08, 2015 | 1998 Ford Explorer
Printer is printing with a lot of lines
If the lines you are getting are white then you have clogged print nozzles. Typically the nozzles clog when old ink plugs up some of the nozzles on the print head. These nozzles can't spray ink onto the page and you end up with white lines. You would need to replace the print head but I would recommend you clean off your cap and wiper assembly first. If you don't and there is a bunch of old ink built up, you run the risk of clogging up the new print head and having the same problem.
Nov 04, 2013 | HP Officejet Pro 8600 e-All-in-One Printer
Not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartridge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
Everything is setup properly and the printer actually attempts to print, but nothing is showing on the paper---the ink carts are full, but I have not used printer in a year
It could be that the nozzles on your cartridges have clogged due to long period of non-usage. Try to follow the steps below to clean the print cartridge nozzles:
Using the computer:
  1. Load plain paper. For help, see Loading paper.
  2. Open the Lexmark Solution Center. On your computer, click Start menu > Programs / All Programs > Lexmark 4300 Series > select Lexmark Solution Center.
  3. From the Maintenance tab, click Clean to fix horizontal streaks.
  4. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print the document again to verify that print quality has improved. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Using the control panel:
  2. Press Menu. The menu appears.
  3. Press the down arrow button until you highlight Clean Cartridge. Press Select.
  4. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Aug 15, 2011 | Lexmark P4350 All-In-One InkJet Printer
No steam no spray from Iron...pump on tank is working Iron is getting hot
It is most likely a clogged nozzle.You need to use only distilled water in the iron cause the calcium and minerals will clog it.To clean the nozzle,buy some Lime,Calcium and Rust cleaner and soak the nozzle in a small container of it.If it isnt to clogged ,you can even clean it with vinegar.
Aug 06, 2011 | Euro-Pro IR4005 Iron
No pressure out of wand have water flow old style wand no turbo motor runs good sounds like it should be full pressure
Hi and welcome to FixYa, I am Kelly.
From your description of the problem:
"motor runs good sounds like it should be full pressure" This sounds like the wand nozzle is clogged behind the nozzle. Remove the nozzle and check for debris behind the nozzle face. All it takes is for a tiny piece of particulate to block the nozzle orifice. (Dig out what ever you find behind the orifice. After you check and re-test the nozzle if you still have the problem there is a lot more that can be done to troubleshoot. I just think you have a clogged nozzle at this time. If the nozzle was not clogged... respond here and I will pass on more information. I think we can easily correct this problem.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Karcher 2500 PSI Pressure Washer
Only one winshied wiper spray works
Check the rubber hoses to the sprayers. If they are on the hood they can come unplugged when you open it. Have a friend work the sprayers as you watch for leaks. An old toothbrush can be used to clean spray nozzles by scrubbing over the hole.
Feb 13, 2011 | 2004 Chevrolet Cavalier
I think the power head is clogged with pine needles. The carpet head is not picking up. How do I open it to clean it out?
Make sure you have suction at the end of the hose. If not, the clog is most likely in the hose. Detach hose from vacuum and wand. Drop a coin into one end and allow it to fall through. If it doesn't drop out, the clog is definitely in the hose. Then visually check the wands for a clog
Disassembling the power nozzle is not necessary, or recommended. First, ensure the clog is in the power nozzle. Drop a coin in the wand end and see if it falls out. If not, the clog is elsewhere. You should be able to clear the power nozzle by disconnecting the wand. Use the handle of a table knife to try to push the clog back through the power nozzle, toward the brush. If that doesn't work, try using long nosed pliers to clear the clog.
Jan 04, 2011 | Rainbow 75th Anniversary Canister Vacuum
03 windstar/washer fluid
Initially, your concern could be caused by:
  • clogged hose/tubing from washer pump to nozzle;
  • clogged nozzle;
  • faulty spray pump (inside the washer bottle);
  • faulty switch;
  • faulty connector/wiring.
In most cases, it would be clogged nozzle or blocked hose/tubing.
Good luck and Thank you for using FixYa.
Dec 05, 2008 | 2003 Ford Windstar
Steam Nozzle
I've only had it fly off once.  I think I didn't put it all the way on.  Also make sure you clean the nozzle every time you use the steamer.  Milk will clog the nozzle otherwise.  My maker is right beside the sink and I rinse the nozzle immediately after steaming milk.  I also run it through the dishwasher at least weekly.  (This isn't a substitute for immediate clearing of the nozzle.)   A clogged nozzle will always blow off the end.
Aug 12, 2008 | Krups XP4030 Espresso Machine
Capresso Jura-Impressa C9 One Touch Espresso Machine Logo
87 people viewed this question
Top Capresso Coffee Makers & Espresso Machines Experts
Lawrence Oravetz
M.B. Nataraj
M.B. Nataraj
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
