Question about Acer AL1715 17" LCD Monitor
My display has rotated and I can't fix it
I accidentally rotated my desktop appearance and can't fix it!
  • 1 more comment
  • tusshill May 17, 2009
    I do not have nvidia
    Thank you for commenting...I just didn't have nvidia.
    Hold ctrl and alt down while simultaneously pushing up arrow!!!! Wow! A friend figured it out for me!
    Sniper:
  • 85 Answers
Go to control panel if you are using nvidia there should be an Nvidia control panel icon double click on that, click the plus next to display then click on rotate and make sure it is set to no rotation.
Posted on May 17, 2009
  • DWDpcRepair May 17, 2009
    if you go to your control panel then display what tabs are listed?
Touchscreen
start computer, right click on empty spot on desktop, choose screen resolution, left click and choose landscape on resulting screen, then click on flipped screen. Should go back to normal. This usually happens when you accidentally press alt ctrl arrow key.
Mar 24, 2014 | Acer Aspire V5
Tip
My screen has been accidentally rotated 90 or 180 degrees, how do I resolve?
If you portable display has been accidentally rotated 90 or 180 degrees this is easily returned to normal for the Intel Graphics Display by pressing the following keystroke:
CTRL+ALT+UP ARROW
on Jan 10, 2010 | Computers & Internet
My display screen reverted lol how do I correct it please
Try either of the followings if you are Windows 7 user:
1. (For built in display) Right clk on the desktop screen and point to "Graphic options". You will see a drop down list where you can find "Rotation". Point to that "Rotation" and you will find the "Rotation" options.
2. (Seperate monitor) If you or someone accidentally or intentionally click on the monitor "Menu" button. You will have to find that on the monitor's "Menu" and locate the reverse display option and correct it. Since monitor differs from one another, I can't give to the exact button to press :). Good luck
Aug 08, 2013 | Computers & Internet
My login screen has turn upside down
Is it only your login screen? or is it the entire operating system? Does it fix after you log in?
Press [Ctrl > Alt > Up arrow] (all at the same time) to revert back to normal orientation. If it is only the login screen, then it may be a issue with the Operating System.
Aug 28, 2011 | Advent Netbook
My aspire screen is upside down and the picutures are also upside down. How can I fix it?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Apr 02, 2011 | Computers & Internet
My screen rotated but i dont know how to fix it?
depending on your OS, go to your display properties (right click on desktop) settings there to rotate your screen back, usually display/rotate display
Jul 14, 2010 | ASUS m6n Notebook
Hello I accidentally changed my settings for my display monitor from portrait to landscape and unable to revert back. Can you help me please?
you may change the setting through the display setting icon in the system tray and rotating the screen
please do rate the solution
Jan 02, 2009 | E-Machines eMachines Desktop PC
I dunno what I pressed, but my desktop is sideways
If you have an Intel Extreme Graphics card, check this.
Right Click on your desktop and choose Properties
Click on the Settings tab> Advanced button> Intel Extreme Graphics tab>Graphics PropertiesDisplay Settings
UNCHECK Enable Rotation then Apply.
Dec 01, 2008 | Compaq Presario Notebook
Picture is sideways
The problem is most likely not with the monitor it is the computer. Some graphics cards have shortcuts to turn the display. Most likely you accidentally hit this shortcut. Most are done with Cntrl/ALT/Delete. Regardless lets get it back to normal. If you right click on the desktop somewhere and select Properties from the box pops up you should get to the display properties. From here select the Advanced button from the settings tab. You should get the Plug and Play display box. Selet the Display adapter tab. Mine happens to be Intel it is usually the tab on the top and takes up the whole length of the box. From this box there should be button for display properties ot something similar. If you check the different tabs in display props there should be a setting for rotation. Set it back to zero. I would deselect the Enable rotation so it does not happen again by accident. I hope this helps. You may find things a different on your PC but this should get you to the right place to fix it. I see this happen a lot. I always disable this on people PC's that I repair for them to avoid calls like this. It is easy to mess up.
Dec 01, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Project will not display entire computer desktop
Hi, have you checked the zoom function, or magnify function?? Try zooming out in case in accidentally go zoomed in.
Nov 20, 2008 | NEC VT460 Multimedia Projector
Acer AL1715 17" LCD Monitor Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
