Question about Blenders
Farberware blender parts
A metal ring fell off the bottom of our 103742 blender recently. This morning it worked fine but this evening the whole blade unit started wobbling. Is this fixable or better to replace? Having trouble looking up parts. Thanks :) Melanie
5 Suggested Answers
SOURCE: stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
Posted on Dec 16, 2007
SOURCE: Kenmore KMB048 Blender
1800KENMORE
Posted on Aug 22, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: CA 4203 model #, Smoothie 700 Pro
Here's the parts order form:
http://www.focuselectrics.com/finditem.cfm?itemid=4287
-Tha Mp3 Doctor
Posted on Mar 27, 2009
  • 7 Answers
SOURCE: Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Posted on Jan 26, 2010
Farberware 103742. Where can I get replacement blades?
Check with a local appliance parts supplier.
Feb 13, 2016 | Blenders
I need a base replacement part for our 103742 model Faberware Blender. Can anyone give my a phone number, or a website? Thanks ever so much, Emily
Go to this webpage
http://www.farberwareproducts.com/products/blenders/blender-with-single-serve-cup-103742.aspx
Click on the link (in red) at the bottom of the page: 103742 Use and Care Manual (actually you might try clicking the link on this answer). You will be prompted to open/download the pdf . You might download & save the manual if you don't already have it. On the first page (top left) you will see
Customer Assistance
1-855-451-2897 (US)
23.December.2014
Dec 23, 2014 | Faberware Blenders
Bl 5000 replace support ring
e-mail the manufactor maybe they have some.
Jan 31, 2013 | Black & Decker BL5000 ProBlend Work Top...
When I use the blender it is difficult to get it tight enough on the bottom so that the liquid does not pour out from the bottom. The ring is not cracked. I have had this problem for a long time and it...
Try tightening the ring by (unplugged), align and tighten the base ring, rubber touching glass, then the blade plate assembly, then the ring....Then place on the machine, press down and tighten more...
I find that you cannot sometimes get enough tighening by hand, due to the dimention of the ring and the human hand...
Oct 27, 2010 | Back to Basics Smoothie Elite Work Top...
Black & Decker BLC12600B 650W Cyclone 12-Speed, the on button blinks and the blender is not working. I have put into different sockets, it just doesn't work.
Unplug the blender. Use a baking soda and vinegar solution to clean the metal contacts on the bottom of the metal blender blade. (You will see a small circular inverted washer looking thing). Use the solution on the main blender unit also. (You will see a small circular metal piece in the center) Scrub them both with the solution and wipe. These seem to be some type of sensors. I then replugged the blender back in and it worked for me!! Good luck!
Sep 13, 2010 | Black & Decker BL14500 Crush Master Work...
Cyclone blender - on light blinks and it won't operate
Had this problem couple of times. pushed the power cord in the blender as if there is lose connection inside. It worked.
Jan 03, 2010 | Black & Decker Blenders
Unit seems to work fine, but when the pitcher is attached, the blade hardly spins. It seems like it is loose or something. I can manually spin the bottom piece of the blade assembly, but the blade itself...
Depending on the age of your blender, a new blade assembly may be available. I would recommend calling Kitchenaid Customer Service for pricing. Their toll-free telephone number is:
1.800.541.6390
Jul 27, 2009 | KitchenAid KSB3 Classic Work Top Blender
Stopped blending
May 17, 2007 | Waring PBB 25 Professional Work Top...
Open Questions:
Blenders Logo
1,347 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
