Question about Graco 6 Speed Opentop Reclining Swing Gingham
Swing does not work when power cord in plugged in do you get cover off
I need a Grayco baby swing power cord.
Fixya does not sell Grayco baby swing power cords.
Jan 22, 2018 | Baby Gear
I cant pull the starter cord on mt coleman ct200u
Remove cover over starter pulley.
Cord wraps around this.
When cord is pulled, centrifugal force swings spring-loaded weights out, to engage the starter gear.
Check that weights are releasing when not pulled.
And that cord is still on pulley.
May have wound off the side.
Nov 22, 2017 | Coleman Garden
Fisher price oceans wonders cradle swing music doesn't work ; help please
try looking at the stand that holds the swing, when you put it together maybe you missed some cords that would only connect together that do not plug into the wall.
Jul 16, 2012 | Fisher Price Ocean Wonders Cradle Swing
Hi there,i have been given a fisher price power plus swing and dont have the cord. when i go to **** smith's what kind of cord do i ask for i know that i need a 6v dc but have u any more info because i...
I checked, and they don't list any specifications for the adapter (listed as a Plug-In, 3rd Row, 2nd item):
https://store.mattel.com/Results.aspx?Ntt=POWER PLUS SWING&tc=BestMatch
And they're on back order. The page above has a link for a live chat session with one of their agents, which I'd recommend, or you could call (US and Canada) 800-432-5437. Maybe they can get the specs for you.
They shouldn't mind, since they don't have the item in stock.
Good luck, and I hope this helps!
Jul 01, 2011 | Fisher Price Toys
I want to insert headphone jack and need to
There should be a swing plastic cover on the front underside of the phone for plugging in the headphones line cord plugged in and handset cord plugged in the middle jack is for heanset.
Oct 05, 2009 | Nortel Meridian M3820 Corded Phone
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Power plug on laptop not working
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system1.gif.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
Feb 05, 2008 | AMD BALANCE A535 NOTEBOOK MOTHERBOARD WITH...
I see no way to plug my ipod into my coby mp37
I think the input is right under one of the legs that swings the cover open. I just looked at mine but can't try it until I get a cord for it. Let me know if that works.
Sep 12, 2007 | Coby CS-MP37 Computer Speakers
Graco 6 Speed Opentop Reclining Swing Gingham Logo
64 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
