Question about Mattel Barbie Remote Control Pink Corvette Car
Barbie remote control corvette wheels won't turn
Motor works, but wheels won't turn
2 Suggested Answers
SOURCE: There is no response to
The solution to this problem may not be the answer you want, but there are 2 solutions for this unit. The first one most easy, get different batteries I have had same problem and just got different batteries and then it worked. The second thing to do is it needs to be taken back because it is defective. That happens a lot even when toys like this are new, they get played with a lot at stores and dropped and so on.
Posted on Dec 28, 2010
We purchased two Barbie corvettes for twins and it seems that one remote controls both cars. Is there a different setting where they can control their own car?
Hi Janet, unfortunately this I'd due to the transmitter frequency being the same! This should have been pointed out to you when purchasing both items together! The packaging should indicate this too! I race remote control cars and on the higher end transmitters the frequency can be changed so all racers are on different frequencies but this would not be the case for you!
Oct 26, 2014 | Mattel Barbie BARBIE Remote Control...
My granddaughter's barbie cruisin' tunes jeep only has fast gear, no slow or reverse.
check and see if both wheels are spinning, if not you have a bad motor which would cause the other gears to not work
Jun 24, 2014 | Fisher Price Power Wheels Barbie Jeep
Can I get a replacement remote for a p3494 barbie corvette? Or is there a universal remote? It's 27MHz.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Dec 30, 2012 | Televison & Video
After a year in storage, jeep won't work.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Jun 06, 2012 | Fisher Price Power Wheels Barbie Jeep
Broken barbie-kelly doll power wheels
You have to push the horn to make it go. I had same problem. Gave to hubby to look at, He had it going in minutes.
Dec 24, 2011 | Fisher Price Barbie - Kelly and Tommy...
My daughter's barbie power wheel jeep keeps slipping out of gear and won't drive.
make sure that the cogs on the tires are in tight contact with the drive motor, you might have to add some washers to take up the free space
Oct 06, 2011 | Fisher Price Power Wheels Barbie Jeep
There is no response to barbie corvette when put batteries in car and remote controller except lights on car turn on
Dec 28, 2010 | Mattel Barbie Remote Control Pink Corvette...
Check abs system lite on how do you find the code list
ABS Fault Code List 1991 Corvette (C4)
Code Definition
21 Right Front Wheel Speed Sensor Fault
22 Right Front Toothed Wheel Frequency Error
25 Left Front Wheel Speed Sensor Fault
26 Left Front Toothed Wheel Frequency Error
31 Right Rear Wheel Speed Sensor Fault
32 Right Rear Toothed Wheel Frequency Error
35 Left Rear Wheel Speed Sensor Fault
36 Left Rear Toothed Wheel Frequency Error
41 Right Front Solenoid Valve Fault
45 Left Front Solenoid Valve Fault
55 Rear Wheels Solenoid Valve Fault
61 Pump Motor or Motor Relay Fault
63 Solenoid Valve Relay Fault
71 Electronic Brake Control Module Fault
72 Serial Data Line Fault
75 Lateral Accelerometer Fault (Short ot Open)
76 Lateral Accelerometer Fault (Signal out of Range)
Mar 12, 2010 | 1991 Chevrolet Corvette
1986 corvette fuse box locaTION
Hello;
Your fuse panel is located under the hood near the battery. Drivers side. Hope this helps; rate me high
Thanks;
Rich
RPM Northwest
Sep 07, 2008 | Corvette 1:8 Remote Control Chevrolet...
Mattel Barbie Remote Control Pink Corvette Car Logo
50 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
Tracy E
Level 1 Expert
Are you a Mattel Toy Expert? Answer questions, earn points and help others
