Question about Lionel Crafts & Hobbies
Brand new Overland Flyer steam locomotive is not smoking. Any ideas?
Train set 6-30188. Has not made any smoke, right out of the box.
  • 134 Answers
SOURCE: bachmann overland locomotive has trouble staying on tracks
hit it with a bigger hammer!
Posted on Feb 19, 2009
  • 906 Answers
SOURCE: Need replacement smoke element for circus
good day,
hope this link below will solve your problem.
toys
Posted on Jul 29, 2010
  • 13 Answers
SOURCE: I bought the 6-30089 Pennsylvania Flyer Train Set
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Posted on Jan 18, 2011
  • 34 Answers
SOURCE: My 2-8-4 Locomotive stops at
This is a common problem with FasTrack Remotes and Manual switches. It is relative to where the center roller pickup is in relation to the wheels (common connection to outter track rails). Solution is to put electrical tape on the outter rail that forms a V between the turn in and the straight away. This elliminates about 1.5" of track discontinuity. It also eliminates wheel sparking that pits the surface of the outter rail. Wish I had a better solution short of taking the switch apart and doing some rewiring.
Posted on Sep 04, 2011
residentoccu
  • 161 Answers
SOURCE: why is the locomotive sparking while going on the track
Sparky's is a common nickname & one
of the joys of our track powered trains.
Clean your wheels and track, it will help
lessen the sparking. Also make sure
your track is level without gaps
between the track sections.
hope this helps.
Posted on Jan 23, 2013
Replace rubber tires
remove screw that attaches the side rod to the drive wheel, place traction tire in groove in drive wheel, replace side rod & screw.
Feb 03, 2014 | Bachmann Ho Usra 0 6 0 Steam Locomotive...
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
No smoke tryed every thing
Follow the link to the Lionel Service Document/Manual
http://www.lionel.com/media/servicedocuments/6299711323250LEGACYMallet.pdf
This link is for the customer Service Product Video:
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6371
Feb 16, 2013 | Lionel 628076 Nickel Plate Usra 2662...
What is lionel smoke pellet tamper used for? Why needed?
Yes, you do just drop the pellet in...
But if there is any kind of crud built up in the
smoke stack, it may not allow the pellet
to seat on the heating element. Thus the
tamper is included to allow you to push
the pellet all the way down. If you don't
have one, a piece of wooden dowel the right
diameter can be used.
Jan 23, 2013 | Lionel Toy Trains Smoke Pellets
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 | Toys
Locomotive no longer smokes
If the smoke unit was working, and no longer does, it may be burned out. Did you turn the unit off after running it out of fluid? If not, it will need to be replaced. The switch is behind the smokke box door on the front of the boiler. I'm not sure if the smoke unit is a warranty replacement part, but a check with Bachmann Parts & Services & they will give you an answer.
http://www.bachmanntrains.com/home-usa/prod_serv.php
Your Locomotive is commonly called the Bumble Bee.
Jan 14, 2012 | Bachmann G-gauge Big Hauler - Ebt Boxcar...
Polar Express locomotive will not smoke with smoke fluid in stack and smoke switch on.
You may have to check if there is power to the heating element. You can also check to see if there is too much fluid. You can also put the engine in neutral and tap the chimney hole a few time to kind of "prime" the smoke unit.
Mar 16, 2011 | Lionel Polar Express Train Set
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Crafts & Hobbies Logo
Top Lionel Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
