Question about LG Lsb316 Sound Bar With Wireless Subwoofer
My sound bar is stuck on mute - LG Lsb316 Sound Bar With Wireless Subwoofer
Volume on Samsung stuck at zero
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
http://electro-medical.blogspot.com/
Aug 25, 2016 | Samsung Televison & Video
We have the sound at 100 and it still is low. Sounds like the speakers are in the back. How do I get the TV louder?
Check whether the audio is muted in full, or half muted. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jan 31, 2016 | Toshiba 32C110U 32 in. LCD TV
Flashing blue light on sound bar. No sound
Double check to make sure you don't have the "mute" on. Usually a flashing light indicates that the volume has been muted.
Mar 08, 2014 | Sony HT-CT100 Theater System
Sound is not
1) Check the task bar sound icon mute active or not (Tick mark view on mute box)
2) Sound icon not in task bar check device settings.
3) Go control panel > System > Hardware > Device manager
4) Sound, Video, game controllers view problems.
5) Re-install Sound card driver.
Mar 26, 2011 | Computers & Internet
My acer netbook is stuck on mute
if the little x over the volume bar is still stuck after moving it up you may have to hit the function key (fn) on your laptop and hit one of the F1-F12 KEYS that look like a mute or volume symbol also there should be a mute button on the laptop itself. if all that fails. go to (xp) right click on my computer -device manager-and see if you have a red or yellow x over your sound sound devices (win vista or 7) go to computer, sys prop on the top then device manager. if you see any of htose yellow or red warnings you will need to re-download the audio drivers from acer website Let me know if this helped.
-Brian
Mar 19, 2011 | Acer Aspire One PC Notebook
HP dv5 1225ca stuck on mute
Go to the HP Support site. Click on "Drivers and Downloads" tab. Enter the p/n (product number) from the white label on the bottom of your laptop in the box where they ask and go. The next page will offer you a chance to choose the Operating System you're using. Enter the correct one and you'll be taken to the Drivers site for your laptop. Look down the list for HP Quickplay and HP Quick Launch Buttons drivers. You must install the QUICKPLAY driver first. Also, look for the Sound category and download and install that driver as well.
That should get you going.
Jul 12, 2010 | HP Pavilion dv9000z Notebook
Volume stuck on mute
I don't think you're stuck on mute I think you're having problems with your sound card. Go to device manager; if there is a yellow or red sign on sound then right click and try reinstall driver. Let me know if you have any questions. Pls rate this solution.
May 07, 2009 | Dell Latitude D600 Notebook
Zenith pro851x 1994 projector stuck on video mute
try holding in the power botten for 5 seconds this will reset some models ...also try to unplug for 5 min then plug in and try again
hope this helps
Dec 11, 2008 | Televison & Video
I was given as a gift a acer aspire 3002CLi laptop and i must of muted the sound and i dont know where the volume control is please help.
hi, you want mute the sound ok, it's easy. After you enter the windows see the task bar it contains more icons and application .In the corner of the task bar you can see the clock or time display before that more icons there you see the sound icons it's like the speaker . Double click it the volume control comes select the first options volume bar and select the option mute all.if you could not get the icons from the task bar . then goto
  1. start menu
  2. control panel
  3. sound and volume controls
  4. select the sound control tab
here you can get the voume control tab . after all these process you cant get it please inform
Apr 28, 2008 | Computers & Internet
LG Lsb316 Sound Bar With Wireless Subwoofer Logo
172 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
