Question about Thermador Kitchen Ranges
I have p366cs, now i cant use the oven because it keep turns off everytime i turn it on. about one or two minutes or after i can hear the oven burner fires up, its click off ( turns off)the light on the panel turns off and blinking also the light inside the oven. thanks eddy
  • eddysprig May 18, 2009
    the stove is working normal, and the oven fire up as usual ( feel the heat) but it is not long time maybe two or three minutes and shut off,
    and some how i cant view the picture
    thanks
  • 749 Answers
Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
Posted on May 18, 2009
    Sergeant:
  • 326 Answers
This is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristicsshould look like.
also the other problem is gas shut off valve.if that valve goes faulty.this can happen.
get the valve checked.
the valve gets tripped when gas is required to be supplied and it shuts off .
also it can be spark moduler problem it gets tripped the whole gas range shuts off.
the cost of spark moduler is $75
you can get the required parts at
www.repairclinic.com
thanks.
please do rate the solution.thank you for using fixya.keep updated
Posted on May 17, 2009
Stoves 720EF oven switches off after 20 minutes
CHECK THAT THE OVEN TIMER IS OFF AND NOT OPERATING EVERYTIME YOU TURN THE OVEN ON IT AUTOMATICALLY SWITHES THE OVEN OFF AFTER 20 MINUTES
Oct 16, 2014 | Ovens
Brief power cut but, timer light did not come back on. Cant use main oven. Top oven fine,isthere a trip switch?
Hello everytime the power goes off & then comes back on my oven won't work until I turn the knob for the timer around as far as it will go then back again. My oven is rather an old type but maybe if you reset the timer or turn it that may help. Or check the meter box as well. dee
Dec 27, 2010 | Ovens
My stove (Caloric) keeps making a clicking nose when all burners and the stove are turned off. I would appreciate any suggestions for how to fix this
This means that the oven has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the clicking sound, then try turning the oven off and on again. If you still note the sound turn off the power to your oven and wait five minutes before turning it on again. If you hear the beep or see the any code when you try to bake or broil again,
then you will have to open the oven to solve the problem by checking on the panel carefully if there is any over flow of water on the panel or the element will need to be replace.
thanks.
Sep 29, 2010 | Stoves Ovens
I turn on oven and can smell gas for a minute,then hear it ignite
I tapped on the valve a couple of times and it seems to work fine now.
Dec 09, 2009 | Kitchen Ranges
Oven and broiler will not stay on.lights blink
The cooling fans under the cook top must blow to close fan sail switches. fans stop , oven shuts down. You may have a problem with your main controler board. Shut off yor breaker to range for at least 20min. retry, if it still does same thing your main board is NG. Its burried under the right side burrners.
I recomend calling thermador for service tech. Its not a do it your self thing.
Nov 03, 2009 | Thermador PG486GEBS Stainless Steel...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Tecnik tkc8525/2 SMOKES OUT EVERYTIME IT IS TURNED ON.
It sounds to me that you have a build up of fat and grease,, and that is what the smoke is, the fat burning off the element(s).. If the oven is working o/k otherwise, then just let it burn all the fat and grease off.
Plz rate this solution.
thanks.
Dec 17, 2008 | Tecnik TKC8525 Double Oven
Spacemake xl 1800
just off hand if you have completely removed the power to the microwave and you hear a beeping it is likely coming from another device in your home.... took me ten minutes the other day to figure out the odd noise i was hearing was the low battery alarm on my wife's cell phone.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Kitchen Ranges Logo
61 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
