Question about Lionel Crafts & Hobbies
Brand new Overland Flyer steam locomotive is not smoking.Train set 6-30188. Any ideas?
  • 135 Answers
SOURCE: bachmann overland locomotive has trouble staying on tracks
hit it with a bigger hammer!
Posted on Feb 19, 2009
SOURCE: how to change the battery in Brio's mighty red
If you look in the funnel there is a screw. Undo this and the front comes off and the batteries will pop out. Put in the new batteries and replace the funnel and screw.
Posted on Feb 20, 2010
  • 906 Answers
SOURCE: Need replacement smoke element for circus
good day,
hope this link below will solve your problem.
toys
Posted on Jul 29, 2010
  • 13 Answers
SOURCE: I bought the 6-30089 Pennsylvania Flyer Train Set
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Posted on Jan 18, 2011
residentoccu
  • 161 Answers
SOURCE: why is the locomotive sparking while going on the track
Sparky's is a common nickname & one
of the joys of our track powered trains.
Clean your wheels and track, it will help
lessen the sparking. Also make sure
your track is level without gaps
between the track sections.
hope this helps.
Posted on Jan 23, 2013
What year is Lionel Train Set 1463?
1463 set with #2036 steam locomotive - 1950
1463 set with #2026 steam locomotive - 1951
Oct 10, 2014 | Crafts & Hobbies
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Car will only go in one direction
please provide more information:
control system used.
locomotive or set number
Jan 29, 2014 | Lionel New York Central Flyer
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
No smoke tryed every thing
Follow the link to the Lionel Service Document/Manual
http://www.lionel.com/media/servicedocuments/6299711323250LEGACYMallet.pdf
This link is for the customer Service Product Video:
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6371
Feb 16, 2013 | Lionel 628076 Nickel Plate Usra 2662...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 | Toys
My train wont go in reverse
Try flipping the "Reverse" switch on the bottom rear of the locomotive.
Jan 03, 2011 | Lionel Pennsylvania Flyer Train Set
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Crafts & Hobbies Logo
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
