Question about Canon Office Equipment & Supplies
Printer error occorred 5802 canon pixma mx377
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
SOURCE: canon printer pixma mp110
My Pixma MP110 keep on displaying "CHECK PRINTER (5800)" Please have m to solve this problem
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: canon pixma mp560 printer error b200
Leave the cover open, turn off, before it off, hold the reset & Start (color) until it completely off, then turn it back on. it works for me, good luck folks
Posted on Jun 05, 2013
What is is the meaning of 5040 error code in canon pixma mx377 and how I can solve it
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
From: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Feb 25, 2016 | Canon Pixma Mx372 Multifunction Inkjet...
Canon pixma printer mx377 show error code 5040 what does it means
Description
Resolution
Feb 25, 2016 | Canon Office Equipment & Supplies
5802 error
This error code is related to a print head problem. Take out each of the ink cartridges one at a time and reinsert them. Next, go to the Maintenance menu of the printer and run the 'print head cleaning' cycle. If there is a 'deep cleaning' option run that, too. If none of the cleaning cycles fix the error code you can try removing each ink cartridge and cleaning the gold contact plate with rubbing alcohol and a cotton swab. Be careful not to leave any cotton fragments behind and allow the alcohol to completely dry before reinserting the cartridges.
Apr 16, 2014 | Canon Office Equipment & Supplies
My printer has a problem. It is Canon MX377 Inkjet Ink.When I opened my printer, it shows B200 error. How should I resolve it?
http://www.mytechtime.com/2011/09/canon-error-b200-how-to-fix-it.html
i hope you got some use of this page.
Apr 19, 2013 | Computers & Internet
Canon pixma mx377 error 5b02
caranya....
untuk meriset canon mx377 error 5b02 gimana
Jan 11, 2013 | Canon Pixma Mx372 Office All-in-one Print...
Driver for canon pixma mx377
tambuuuuuuuuuuuukkkkkkkkkkkkkkkkkk,,,,,,,,,,,,,,,..............
Dec 13, 2012 | Canon PIXMA MX372 - multifunction fax /...
Mx377 reset waste ink counter
call me i can help you w/ your prob on printer 09234858902 derwin
Aug 13, 2012 | Canon PIXMA MX340 Wireless Office...
Free download canon PIXMA MX338 software
canon printer mx377 we have problem with it
the printer show alarm 'contact service centre'
what can I do for it
do we can download mx377 resetter software
Nov 25, 2010 | Office Equipment & Supplies
Error code 277-5802
what i can tell you is that there is a comunication problem between the printer board and main controller. the only suggestion i have for you is to call for service and have someone come out and check all the boards. unless you know how to remove them and try putting them back in
Jan 28, 2010 | Canon imageRUNNER 8500 Copier
533 people viewed this question
old marine
old marine
