Question about Sony Walkman NWZE374/BC 8GB MP3 Player Black
Stuck on hold - Sony Walkman NWZE374/BC 8GB MP3 Player Black
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Tip
FIXED keyboard stuck in fn mode ...
keyboard stuck in fn mode ASUS eeePc .. what you have to do is press and hold the Fn key, then while holding the Fn key, press Num LK or Number Lock key, That should fix it. Good luck!
on Feb 10, 2010 | Computers & Internet
Grand Marquis stuck in park
Because of the inclination may be holding it stucked,u let the car from the hand brake and it stucked need to pull front/back to pop it.never let the hand brake before putting it out/in park mode.U may let it down if firmly holding the brakes ,yet put out of park before release the brakes.
Oct 22, 2013 | Mercury Grand Marquis Cars & Trucks
My sony mp3 player is stuck on hold. How do I get it off hold
it stuck yesterday and its still working. cannot restart.
Jul 13, 2010 | Sony Walkman NWZ-B105F MP3 Player
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
Nwz-s639f stuck on hold
try reseting it if theres a way you can. or if theres a hold button
Sep 03, 2009 | Sony Walkman NWZ-B105F MP3 Player
Stuck on frozen apple screen
The only thing you have to do is when its stuck in recovery mode (apple logo displaying forever) you hold down the home button and plug it into the back of your computer while holding down the home button. It worked for me, and i think it will for everyone else too.Hope it helps.
Jun 16, 2009 | Apple iPhone Smartphone
Sansa clip jammed
Rebooting the device usually helps with this.
Any time it's 'stuck', you can do a soft reset (reboot) by holding the power/hold button up in the 'on' position while pressing the center-round button for a few seconds.
If it defaults to off, it should restart normally by using the power-on switch.
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Stuck on hold
Sounds like the hold switch itself is bad. You may need to RMA it, or take it to a local electronics repair shop.
Jun 20, 2008 | Sony PlayStation Portable (PSP) Console
Sony Walkman NWZE374/BC 8GB MP3 Player Black Logo
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
