Question about U12A Toys
I need instructions for u12a camera 2.4g
How to charge and assemble battery
Worked when I first tried it
Sony handycam won't work! - Forums - CNET
www.cnet.com > Forums > Camcorders
CNETI dont know if this would work but have you tried resetting the camera? Some have a reset ... I hit the reset button. ... 2. left it powered up without the tape in for about 15 minutes. .... Sony Handycam Digital 8 Usb Streaming DCR-TRV250 NTSC
Fixing dropped compact cameras - Instructables
www.instructables.com/id/Fixing-dropped-compact-cameras/
Instructables*Disclaimer* This is not a guaranteed fix for your camera, if it is insured or ... you take with personal property and your own body by working on your camera, ... after removing the battery and give the battery a charge up if it won't go open it up and ....Tags: camera compact repair assembly dropped take apart digital damaged ...
Jan 27, 2016 | Cameras
Battery lock broken, needs replaced camera will not turn on with a fully charged battery
I had the same problem and was able to find a replacement lock and spring on e-bay from US Camera - P/N 370388337496). They may have none left. Not sure.
I have no instructions on how to install the replacement, but don't think it should be that hard (haven't installed mine yet). It is called a Kodak DX7630 Battery Latch and Spring Assembly.
You can also contact United Camera Customer Service (1-630-595-2525) and talk with them. They are the company that Kodak will send you to for repairs to your DX7630.
The part number From Kodak PartsDepartment (1-800-431-7278 (opt #2) is: F6170 for the latch. The did not have any springs on hand.
Jan 27, 2011 | Kodak EasyShare DX7630 Digital Camera
When I open the lens door the lens doesn't come out. So the camera is not activated. The battery is fine and I can still connect the camera to my laptop. Somewhere I read that there is a little battery...
no there is no such little battery in the camera.there is one battery in the back of camera from which the battery gets power.if the charge in that battery is less or that battery is weak or faulty then this same problem of lens not coming will occur.but if you are confirmed that battery is properly charged and its not weak.then the problem may be either the lens assembly getting blocked or there is a motor inside the back of the lens assembly.the motor actually makes the lens assembly go back and forth.if that motor is got weak then this problem can occur.so the problem is either lens moving assembly got blocked or broken or the motor is weak/faulty. that has to be checked. before going for any internal repairing and checking .just be confirmed that camera battery is properly charged and working.in many cameras it has been noticed that due to weak or faulty battery this types of many problem occurs and replacing the battery solves the problem. this will help.please do rate the solution.keep updated for any further assistance if required. thanks.
Apr 29, 2010 | Canon PowerShot S50 Digital Camera
My camera wont start, it wont even charge please help
There is a problem in your battery either you need to replace it or you can try to charge it through USB.
If you want to charge your camera through USB follow the instruction:-
1) In the computer turn OFF the hibernate, sleep or stand by Mode. 2) Turn OFF the camera. 3) Connect the your camera to the computer through USB Cable. 4) Wait for your camera battery to charge (Approx. 3 hours)
This may resolve your problem, Else you need to replace your battery
Rating the solution is highly appreciated...Good Luck
Mar 03, 2010 | Kodak EasyShare MD853 Digital Camera
Olympus D560 - the lens will not extend, the camera beeps. I've changed batteries, but "new batteries" can also be dead. Suggestions?
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $87 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 17, 2009 | Olympus Camedia C-350 Digital Camera
Lens stuck open will not retreat battery fully charged when it is turned on lens moves in and out but will not fully close
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $66.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 20, 2009 | Olympus FE-280 Digital Camera
I need better instructions on how to use this camera
the blinking light is the power button. When it no longer blinks, it is fully charged.
Apr 18, 2009 | Kodak EasyShare M1033 Digital Camera
Replacing battery questions
can you please advise where I can find out when the battery is running low on my m753 digital camera I have read all the instructions in the manual but there is nothing in this to let me know.
Also how long do I need to charge the battery for when it does run down.
Mrs Livermore e-mail address as follows.
LivBrn@aol.com
Nov 16, 2007 | Cameras
Camera won't turn on with charged battery
bad battery, hoever the battery catcher assembly can fail. Larry
Nov 07, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Toys Logo
87 people viewed this question
Top U12A Toys Experts
Andrew Taylor
Andrew Taylor
Are you an U12A Toy Expert? Answer questions, earn points and help others
