Question about Eviant 7" 8 GB Wi-Fi Purple Tablet Android 4.1, LCD Touchscreen, 1024x600
NEW EIVIANT 7" TABLET HAS A BLACK AND WHITE SCREEN WITH A FEATHER ON IT. CAN IT BE FIXED?
SCREEN WONT CHANGE FROM A BLACK AND WHTE SCREEN WITH LINES AND A FEATHER
My kurio talbets has a white face
Press and hold the reset button on your tablet for 40 seconds and then re-press. See if that helps.
Jun 14, 2017 | Tablets & eReaders
My dragon touch 7 inch tablet doesnt start up. the screen goes directly to white and it wont go from there
There are a couple things that could cause that. Does it still have sound? If you can hear the sound continue, it is likely caused by either damage underneath the screen, moisture inside it, heat/sun damage, etc.
Jul 22, 2016 | TabletExpress Dragon Touch 7 Black Dual...
Wont boot and the screen has lines
This is a bad sign. If the lines are up and down then the video chip in the main board is bad. It could also be several other issues with the main board.
Feb 12, 2016 | Iview 1010NB
Why did screen turn white?
probably a connection problem with the board inside,below is a link of how it could possibly be fixed
Android Tablet White Screen fix
White screen and lines on tablet repair no video Fix it Fik
Jan 30, 2016 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
Dec 28, 2014 | Tablets & eReaders
Eviant 7" 8 GB Wi-Fi Purple Tablet Android 4.1, LCD Touchscreen, 1024x600 Logo
Top Eviant Tablets & eReaders Experts
Vladimir Frolov
 Russ Hill
Russ Hill
Are you an Eviant Tablet and eReader Expert? Answer questions, earn points and help others
