Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Scanning a combination of one-sided and two-sided documents
We have a Konica Minolta bizhub 250 printer which has been set up for faxing and scanning.  I can't figure out how to scan a combination of one-sided and two-sided documents, so that they all are emailed to me as one attachment.
  • 167 Answers
Use the "Separate Scan" button on the panel. By pushing this you are telling the scanner that you have separate scans to scan as one document. Once all files are scanned, push the separate scan button again to indicate you are finished scanning.
Posted on Jan 08, 2008
How do i send fax from bizhub 250
Fax line connected to a analog phone line can not be digital, is the fax line plug, phone line good call it and problem or nise.ed into the line connector not the tel connector fax kit installed properly and set up correctly
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
How to get rid of vertical lines in scanned documents in bizhub 200?
Open the top cover of the machine and clean the small glass on the left hand side. Good luck.
Dec 27, 2012 | Konica Minolta bizhub 200 Printer
Konica minolta bizhub 250 I need to scan many documents to computer says user id and password incorrect
the user name and password have to match the pc. if the pc does not have administrative rights the scan will be rejected most network security software will cause a scan to be rejected also
Sep 25, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
How do you scan to PDF on a Konica Minolta Bizhub 353?
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Jul 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How to fax via Konica Minolta bizhub 250
The fax is an option on the C250.
if it is installed then all you need is to attach the phone line cable.
The option will be available from a button on the Panel.
Apr 23, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
you can see job confirmations under job list, there you see, whats ok and whats not. also paper format you can choose under fax sending screen, before sending fax. probably you caan choose a default page format from utility - user/ admin settings
Apr 17, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
401 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
