Question about Winter Sports
Dalbello ski boot replacement toe heel - Winter Sports
2 Suggested Answers
  • 415 Answers
SOURCE: broken right boot toe buckle
Basically your only hope of getting it fixed is to go to a ski shop and talk to the tech. They'll either get you a replacement buckle from the factory or one that fixed and change it. This is not a simple repair you can do yourself.
Posted on Mar 03, 2011
Binding adjustment
There is (should be) a screw visible on each of the toe and heel pieces when looking down from directly above. That screw will adjust the height of the piece that clamps down on the top of the tabs on the heel and toe of your ski boots. For proper height measurement, use a credit card (or similar thickness card) and make sure you can somewhat freely slide the card side-to-side under your boot when it is in the binding and clamped down as when you are skiing. Too much play, and you will feel a sloppyness while skiing. Too little and you risk the binding not releasing properly caused by stiction. You can find demonstrations on YouTube also.
Apr 04, 2014 | Fischer Skis Fischer RC4 Z 17 Freeflex...
Dalbello ski boot replacement parts
need heel replacement for Dalbello krypton cross ski boot
Nov 13, 2013 | Nike 6.0 Mens Noroc Snowboard Ski Snow...
Heel toe shifter repair
Hi Anonymous, try tightning the pinch bolt that holds the heel toe shift pedal in place to 10 ft lbs. Good luck.
Oct 02, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
Heel to shifter toe is loose
Hi Anonymous, look under the lever on the bottom there should be an allen screw. Good luck and have nice day.
Aug 31, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
MY BIKE SHIFTS HARD GOING INTO 5TH GEAR. THIS IS USING THE HEEL PART OF THE SHIFTING LEVER. IT SEEMS TO GO INTO GEAR EASIER WHEN LIFTING ON THE TOE PART OF LEVER. ANY SUGGESTIONS? THANKS.
The heel and toe shifter is brutal on gear boxes, any motorcycle I have had over the years the heel shift was never used in fact we, we meaning all my friends would ether cut that hell part off or purchase the actual toe shifter and install it. Some of the new cruiser type bikes come with these heel and to shifters and you can hear the rider slamming the gears. The toe shifter is a much more precise feel. You can also feel if the shift has go into the gear or a faults neutral with the hell you slam through it, makes me shiver just thinking of it. A question to you (you don't need to answer it) is how many high performance motorcycles have you see with a heal/toe shifter, I would hope none
Dec 20, 2010 | Honda VT 1100 C3 Shadow Aero Motorcycles
I need toe and heels for nordica syntech f8 ski boots size 190.0 - 190.5. where do i order them?
You can order them from amazon, click here and take a look: Amazon com nordica. Wish you best of luck. Smith
Nov 16, 2010 | Nordica Beast 10 Ski Boot Men's
How do I shift my 2007 v star classic. I never rode a bike before and need to know where the gears are. I have a heel toe shifter
toe down for first, half click heel for neutral, then heel shift for 2,3,4,5. toe down to down shift.
Jun 14, 2010 | 2007 Yamaha V Star Classic
Snowboard boots with reduced length
You may also want to look at how you are setting up your bindings. I have a US 11 foot (29 cm) and with my bindings set correctly have never had any issues with toe or heal drag.
The best way to set up your bindings it to take them off, remove the mounting screws, keep the base plates in and fit your boots into your bindings with the straps still undone. Then, with the board on the floor, position the binding at the angle you like (roughly) and look to see when the toe and heel over lap is even or if you are like me pull the bindings back slightly so that you have little or no toe drag and just little heel drag. It works a treat and I have done this for over a hundred customers over the years.
Mar 15, 2010 | Burton Boxer Snowboard Boots
Atomic 4tix 310 binding toe adjustment.
Did you ever figure out how to adjust the toe piece? I am having the same problem
Mar 08, 2010 | Sport & Outdoor - Others
Vertical adjustment on front binding. Salomon S810 Ti
If you can adjust vertical pressure then you should adjust it as follows.
Put a piece of normal paper (like A4 printer paper) on the toe bit (and heel for that matter) and clip in the boot so that the paper sits between the boot sole and the binding base surface. You should be able to pull the paper out from between the boot and binding without ripping the paper, but obviously without there being a noticeable gap.
If in doubt take it to a ski tech, a bit of cash might save you a broken leg! They might even be able to help you or advise free of charge.
Nov 07, 2009 | Rossignol Used Freeride X 05 Skis with...
Winter Sports Logo
133 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
