What are the jumbo universal remote control codes for vectech tv?
Jumbo universal remote control codes for Vectech television?
  • 4 Answers
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
Posted on Jan 06, 2008
SOURCE: remote code for innovage jumbo universal remote control
i need a code to reset my innovage jumbo universal remote control for a panasonic tv
Posted on Nov 10, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
  • 10 Answers
SOURCE: NEED MANUAL FOR SHARPER IMAGE JUMBO UNIVERSAL REMOTE 1613086
The manufacturer of that remote is Emerson.  Here is the manual.
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
Posted on Mar 27, 2009
  • 144 Answers
SOURCE: Innovage Jumbo Universal Remote Control Codes for the Sansui VCR
Hi there, This should be the PDF file with all the codes you need. Hope this helps!
CBR2009
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
Posted on Jul 24, 2009
LG codes for a jumbo remote
Check these codes. 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Oct 22, 2012 | Jumbo Universal Remote TV DVD VHS...
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
Jumbo remote codes and steps
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button, for TV's not on the list.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Dec 16, 2009 | Innovage Jumbo Remote Control
Need the code for the PHILIPS TV to make the remote work on our tv. I have a Innovage Products Jumbo Universal Remote.
The remote codes for your Jumbo Universal Remote to control a Philips TV are 003, 004, 006, 008, 062, 068, 069, 074, 075, 077, 086, 087, 089, 163, 183, 184, 205, 206, 207, 208, 212, and 213.
Sep 27, 2009 | Innovage Jumbo Remote Control
Need code to sanyo t.v. from emerson remote
Emerson Jumbo Remote code for Sanyo TV. 004 013 049 108 110 180 209.
Emerson Jumbo Remote code for Sanyo VCR/DVD. 042 191
Apr 21, 2009 | Emerson Televison & Video
Bigmatters universal jumbo remote ero4307j
manual de codigos del control bigmatters jumbo universal mod ero4307j
Jul 05, 2008 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
