Question about FrancisFrancis! X1 for Ground Espresso - SS
I need a francis francis x1 portafilter for ground coffee
4 Suggested Answers
SOURCE: I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Posted on May 21, 2009
  • 6 Answers
SOURCE: i have a francis x1 coffee machine need a seal
Call 877-854-4141, which is Empire Fulfillment. If you are not sure if the part is exactly right, ask them to email you a diagram of the part.
Posted on Oct 12, 2009
  • 5 Answers
SOURCE: I need a Francis Francis x3 portafilter for ground coffee
If you have an X3 Trio - you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Posted on Nov 06, 2009
Ground Coffee Kit/Holder
There were two versions of the Francis Francis X1; one without the logo (older) and one with. I guess your only chance is ebay; but why would someone sell the holder without the machine?
May 27, 2014 | FrancisFrancis! X1 Espresso Machine
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
I bought a used Francis Francis x5. I need the part (don't know the name_ that goes on top of the gang head after you fill it with grind before you insert it into the machine- part tamper/part screen......
Tamper?
Any 56mm (or even 57mm) tamper will work for the X5's portafilter. The one that is supplied with the X5 has a detachable screen you leave in the portafilter... but you don't need that. Any tamper will do.
Jan 12, 2010 | FrancisFrancis! X1 - Stainless Steel...
I have a Francis Francis X3 machine and would like the attachment to use ground coffee as at the moment I can only use pods.
If you have an X3 Trio you are out of luck.
Oct 29, 2009 | FrancisFrancis! X3 Espresso Machine
Oct 09, 2009 | FrancisFrancis! X3 Espresso Machine
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
I have a Francis X1 Trio. Has anyone ever tried to use ground coffee and can it work. I hate the pods and would love to try to use regular ground with a tamper, but I'm afraid of ruining the machine.
You need a ground coffee adapter, these are available from various sites online. Do a web search for X1 ground coffee handle and you'll find one. Make sure it's the right one for your machine (check to see if you have the aluminium or brass boiler version)
Just found this site - It's in the UK and I'm not sure if you are but they will probably export to you.
http://tinyurl.com/lhxvg6
Regards
Richard
Feb 18, 2009 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 for Ground Espresso - SS Logo
108 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
