Question about Arris DCT2608
Thomson freeview recorder problems
Keeps crashing not recording any planned recordings
My HUMAX free-view set top box seems to crash after it's been on for about thee hours,then reboots it's self in about four minutes. any ideas?
This device has a fan that will turn on when the temperature of the internal hard drive reaches a certain level. The problem may be due to a faulty sensor, fan or both. here's a forum for this hardware that may be of help: http://hummy.tv/forum/forums/hdr-fox-t2-freeview-recorder.13/
Dec 02, 2014 | Humax Hdr-Fox T2 500Gb Freeview Hd Digital...
Thomson freeview dv3 recorder
Buy one universal remote control, which have setup codes for your Thomsun device. Brand name isn't matter.
May 06, 2012 | Thomson Internal Push Ring,id 2.000 In -...
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson topupbox
hi i have sorted the problem i went on line of the make of the thomson freeview and their was other people with the same problem and they help me by reading their instrutions on their page now it is working .
May 04, 2009 | Thomson DTH8000 DVD Recorder
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Mar 05, 2009 | Arris DCT2608
My Thomson freeview recorder box wont let me record anything as it saya that my drive is full but it freezes when i try to delete some of my recordings
Marriott, You will find that it is only one recording that is causing this. This also happens to my box as well when we tape emerdale on a Monday. look through what has been taped and find out if the minutes used is correct for that programme. if not then you need to do the following in very quick procession.
Press the delete button and confirm as quickly as possible when you scan down the the programme that has not recorded correctly.
Hope this helps
Norrie
Oct 10, 2008 | Televison & Video
Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Jun 04, 2008 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Arris DCT2608 Logo
11 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
