Question about GE Ovens
Self clean j55bf-1 - GE Ovens
Spectra oven. It was going through a self cleaning cycle and was shut off partially through that cycle. Now the door is locked and won't open up. Help!
Door lock has failed to open after cool off start oven into self clean again leave on for a 1/2 min. then cancel self clean motor for self clean should return to normal or lock switch need replaced need a model # on were lock motor is located
Jan 30, 2017 | Ovens
Self clean won't work
could have problem with self cleaning cicuit
Nov 16, 2013 | Kenmore Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Self cleaning stops after about 1 hr with error code F5E5
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Nov 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
HI! I am trying to use the self clean function --it is giving me an E 1- F5 message .. Please advise thank you! Barbara Lash Franklin, Massachusetts
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 03, 2010 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do I use the steam clean self-cleaning oven?
The SteamClean option spot cleans the oven in 20 minutes and is recommended for cleaning light spills on the bottom of the oven cavity. When used routinely, the SteamClean option reduces the need for frequent self-clean cycle use. To use the SteamClean option, pour 12 ounces (1 1/2 cup) of water into the bottom of the oven cavity, close the oven door and push the SteamClean button. At the end of the cycle, consumers wipe out the bottom of the oven, easily removing oven soils. The steam cleaning option is eco-friendly and does not require frequent use of the self-clean cycle, which can create a strong odor. Read this in a post about the new whirlpool ranges
Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
RENTING CONDO WITH SELF-CLEAN WHIRLPOOL OVEN RF376PXDQ
If this a relatively new oven it show have a self cleaning identification on the control area or panel. Just close & select self cleaning option should take about 1 1/2 - 3 Hours
Mar 25, 2009 | Ovens
I have an electric Maytag stove/oven but don't know how to use the self cleaning feature. What do I do?
Dear cooper1914,
There are two types of Ovens that clean themselves.
1) A Self-Cleaning Oven which usually gets locked 1st then set on Self-Clean.
2) A Continuous-Cleaning Oven which is constantly cleaning
Some people prefer the old fashion clean by hand with degreasers but I prefer Self-Clean or Continuous-Clean as there is no need for harsh potent cleaners!
If you have a Self-Cleaning or Continuous-Clean Oven Do Not Clean With Cleaners as it will ruin the flavor of your oven!
Click on the following link for more info @ http://www.essortment.com/all/cleanoven_rbad.htm
Maytag Customer Support Manuals @ http://www.maytag.com/support/manuals_literature.jsp
jackiaria
Tuesday 02-24-2009 11:13am EST (USA)
Feb 24, 2009 | Maytag CWG3600A Gas Single Oven
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
77 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
