Rowa R6828SF vertical bottom foldover, I have used the service mode controls to try to fix but as expected this is a component failure, anybody know which caps etc to replace?
techman
  • 3130 Answers
SOURCE: 27MT5005D vertical foldover
You have bad capacitor(s) in the vertical circuit.
Posted on Dec 06, 2007
freetek
  • 5568 Answers
SOURCE: horizontal lines on picture
Can't advise on entering setup but the lines may be due to the maladjustment of the brightness control on the flyback. There will normally be two adjusters, one for focus the other for brightness.
Posted on Nov 26, 2008
  • 4234 Answers
SOURCE: I have vertical shifted up from bottom and foldover from top down
This is caused by a defective capacitor in the vertical circuit. If you can solder, you should be able to fix this your self. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
Posted on Apr 02, 2009
nicknovikov
  • 100 Answers
SOURCE: This set has no picture on the top third of the
need replaced capacitors in vertical output..
Posted on Jul 12, 2009
gopakumarg43
  • 74211 Answers
SOURCE: Sansui sv29281 has a top foldover. I have replaced a faulty 1uf electrolytic cap in the vertical circuit but still have a problem.
Check and replace all the electrolytic capacitors at the vertical scan output section circuit at one time. Check the all the solder terminals to the vertical scan output IC for loose soldering.
If you wish to get more service details, visit the site linked here. Search the site by type in MY SERVICE TABLE TODAY in the search page at the top right of the display window of the home page, to get gathered all the posts related with the service experiences of the publisher of that site.
Hope it will help you to know more.
Posted on Jan 07, 2017
Good moring ! Ma'am or sir I'm repairing my TV set sharp 21V-W70M the problem is green picture, ill try to changes the degosing coil, and then try to testing to open to picture to become...
If this were a degaussing issue then I would expect to see red, green, and blue but with distortion. That isn't what you're reporting. As has been suggested already, you likely have a component area (like vertical or horizontal sweep) that is malfunctioning because of a failure. The failure could be system voltage oriented or a component board or combination of both. Here is the bottom line, how much are you willing to spend to fix an older TV? If you aren't willing to spend a few hundred dollars then consider why a repairman would want to work for less? By the time a technician puts the set on his bench, opens it, and does preliminary system check you've got an hour invested. If a system power voltage failure caused other components to fail then the problem along with cost to repair quickly escalates.
Nov 26, 2014 | Sharp Televison & Video
Vertical foldover on bottom of 32 inch samsung lcd tv about 3 inches across bottom of screen
usually on all image related problem on all LCD comes from faulty t-con board..but for sure try to play dvd movie to test if the problem is on tv/t-con...
Jul 18, 2012 | Televison & Video
How to open rowa crt tv service mode
rowa tv service model no 14f 1nf
Jul 02, 2012 | Televison & Video
Picture cramped a little on top and reduced half inch bottom
you need to adjust the display setting in the menu option .reduce little from top and botom
Mar 19, 2010 | Televison & Video
Dan
Apr 02, 2009 | Zenith B13A03D 13" TV
Horizontal lines on picture
Nov 26, 2008 | Televison & Video
ROWA RTM-686 Television reciever schematic/service manual
Do you know the remote control number for the RTM-686 please ?
Dazz ifeelgood2002@optusnet.com.au
Sep 03, 2008 | Televison & Video
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Half a screen
The picture on your TV screen is driven from the center to the top and bottom of the screen by the vertical drive circuit. The fact that you can see the entire picture means you have a problem called foldover. This is caused by a failure in the vertical drive circuit where the vertical saw signal is altered by a component failure within the vertical drive circuit. You cannot solve this problem but any good repair shop should be able to correct the problem at a reasonable cost.
Jun 22, 2006 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
