Question about Video Cameras
Safeguard sd106a - Video Cameras
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
Eo1 comes on says take out battery and put back in should work but donot need to use camera now.
JVC camcorders are known for having safeguard problems.
mine was locked into safeguard the second time i tried to use it at 1 month old. i had it repaired and it came back eating the tapes. eating the tapes was blamed on old, or improper tapes. they were all brand new never used JVC tapes.
it came back from service locked in safeguard mode.
i got it back the fourth time and it worked for a few days, then went back into safeguard mode.
the shop had it more than i did during the first year.
when it locked the next time after the warranty was out, i was told the estimate for repairs was $300.00.
unless you want to try to risk taking it apart, the only 2 options you have is to send it in for repairs which is not cheap, or throw it away and never buy anything from JVC again.
i chose option 2.
Aug 27, 2009 | JVC Everio GZ-MG130 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Digital video camera stuck in safeguard mode
model # gr-d396u is stuck in safeguard mode, how do you unstick it
Apr 05, 2008 | JVC Cameras
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Unit in sageguard mode
"safeguard mode" indicates a hard failure, normally associated with the mechanism. Try ejecting the tape if one is in the unit. Do not force the mechanism open as it will cost more have the cam repaired. If tape is defective and can be removed, try using a cleaning tape first, then a known good tape.
Dec 25, 2007 | JVC Digital Video Camera
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
Jun 03, 2007 | JVC GR-D275 Mini DV Digital Camcorder
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
