Question about Refrigerators
Error code FF kenmore chest freezer - Refrigerators
BFixed
  • 104 Answers
SOURCE: Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Posted on Mar 11, 2008
jonniewalker
  • 1031 Answers
SOURCE: Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Posted on Oct 18, 2008
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Posted on Dec 24, 2008
SOURCE: need to replace the 9 volt battery in my kenmore freezer chest.
The manual does not tell you where its at but the 9-volt battery holder is located on the lower left side of the freezer. There is a small panel about 9" off the floor and towards the front of the freezer (left side facing). cd6fa25d-9930-4b53-8883-c0ebcde8413d1.03.01
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
What does it mean when the Kenmore Elite chest freezer flashes FF code
That means the fan has not started like it is supposed to. Unplug the unit from power for a couple of minutes and try again.
Apr 20, 2017 | Kenmore Refrigerators
FF 6 code
What is the model number?This error code FF indicates a problem with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. Sometimes this procedure corrects the problem and sometimes it does, for only a short period of time. Usually in this case, the main board will need to be replaced.
Nov 10, 2012 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I have a Kenmore Refr. Model # 795.77563600 has a Error FF
The FF error code indicates that the freezer fan motor is defective.
You need a new main control board and evaporator fan motor.
The fridge is made by LG, but rebranded as Kenmore by Sears. First 3 digits is the tell. You can call Sears for parts.
LG refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
Sears brand CHEST freezer had beeping noise. I changed the 9volt battery. It still beeps every 10sec. and flashes the number 6 and FF
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Error Code Er FF
Replace the defrost heater and defrost thermostat in the freezer.
Mar 23, 2009 | Kenmore Refrigerators
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Dec 26, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Refrigerators Logo
287 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
