Question about Palm Treo 650 Handheld
PALM TREO 650
MY PALM TREO 650 IS NOT UP LOADING, EVEN WHEN CHARGE FULL ,WHEN I PUT IT ON THE SCREEN STARTS TO UPLOAD AN TEHN FREEZES WAHT CAN I DO  IT NEVER FELL OR ANYTHING LIKE THAT PLEASE HELP
Have you dropped the device before?
Posted on Oct 18, 2007
    Problem Solver:
  • 6 Answers
I would suggest a hard reset.  Be sure that all of your information is backed up prior to preforming these steps.
Please follow the hard reset instructions in the following publication.
(copy/paste this into your browser)
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887)
Let me know if this works.
James
SOURCE:
How can i turn off the annoying LED light?
There are several possibilities. One is a little freeware application called LEDOff. Just Google "palm ledoff" and go to the first site you see. It says it's for the Treo 600 but it works great on my 650.
The other solution is to put some kind of barrier over the light, like electrical tape. If you're feeling adventurous, you could even open the case and put the tape on the inside so it doesn't ruin the look of your device.
I can't for the life of me figure out why the Treo designers used such a bloody bright LED. I mean, it's like a laser! If you try to look at the screen when it's charging you'll likely get a headache. But the utility I mentioned even turns off the charge light.
Dec 02, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Unlock Code.
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Battery does not charge.
hi dear
try this
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
oke
or just try to use
http://mytreo.net/archives/2005/09/charge-your-treo-650-spare-battery-with-seidios-innocharger.html
oke
cropp
Mar 26, 2008 | Palm Treo 650 Handheld
Palm treo 750
try a reset, if that doesnt work, then we can try a hardreset witch also removes all your files from the phone.
If a hardreset doesnt work then the phone is in need of repairs.
Mar 24, 2008 | Palm Treo 750 Smartphone
My treo 650"s just plain freaking out
I have a TREO650 and ran into a somewhat similar issue before. What you did by removing the battery was called a soft reset. There are 4 types of resets; soft, warm, hard and zero-out (personally I would not try this one just because it is difficult to do and it may make things worse in some rare instances).
Here is a website that describes the 4 types of reset and how to do them. http://mytreo.net/treofaq/Treo650Resetting
If the pictures to you aren't as important as getting your TREO working, I would suggest doing a HARD RESET.
As a suggestion for next time. Take your pictures and then transfer them to a 1GB SD card (the TREO 650 cannot accept any size larger than 1GB) and remove the SD card. Use a SD card reader in your PC to extract the pictures.
Good luck.
Feb 18, 2008 | Palm Treo 750 Smartphone
Treo 650 cell phone
buy new battery nimh in ther sit so long loses full charge cant get back .
Feb 05, 2008 | Palm Treo 650 Handheld
Palm treo 650 wont power up
It may be past the point of turning on.
If this is the case, if you connect it through the USB cable to your computer for a little while, it can get a small charge.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
If you can then power it on afterwards, connect it to the regular power charger.
Jan 06, 2008 | Palm Treo 650 Handheld
Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Jan 04, 2008 | Palm Treo 650 Handheld
Palm Treo 650 charging port loose and will not charge
I had this on mine, it seems to be a wear and tear issue, mine has gone back to Palm for a paid repair as it is out of warranty:-(
Kevan
Nov 09, 2007 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
69 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
