Question about Philips PD7012G/37 7-Inch Dual Screen Portable DVD Player
Trying to use our Philips Pd7012G dual screen Portable DVD player says wrong region could someone tell me how to fix please
Purchased online the Philips PD7012G/37 7-Inch Dual Screen Portable DVD Player says wrong region when we try to play a dvd we are in New Zealand
SOURCE: WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Posted on Aug 28, 2008
marketex
  • 371 Answers
SOURCE: Can't run a Dual layer DVD Philips DVD player DVP3005/69
You Don't!
moz-screenshot-2.jpgmoz-screenshot-3.jpgwww.p4c.philips.com/files/d/dvp3005_69/dvp3005_69_pss_aen.pdf
click on the link above and download a PDF on the model you have, and in the 2 pages you will never see any mention of 2 Layer media.
Posted on Apr 25, 2009
papan3000in
  • 6 Answers
SOURCE: my philips dvp642/37 doesn't wanna play my dvds "wrong region"
you have to reset the regional code
Posted on May 03, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
  • 2427 Answers
SOURCE: how do you change the region code to europe on a
its quite easy actually
1.) Press setup
2.) select preferences to go to the preferences page
3.) enter 9 6 5 3
4) select your region
personally I set my players to 0 meaning region free ,, this means that it can player any movie from anywhere without having to setup region any more. Region free players are the best. I'd suggest you set yours to 0 as well therefore you will never have to set up your region again and u can play anything.
good luck.
Posted on Mar 02, 2010
Testimonial: "Thankyou Thankyou, you are a life saver. My 5 year old can watch his DVD's on our next flight. Thanks again for your help...."
Region unlock code
You can get a region free code for your player from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
Feb 14, 2013 | Philips PD9012/37 9-Inch LCD Dual Screen...
How do I unlock region on dual screen DVD player drc69705
Can you please try to use the below steps
Open The DVD Door
Press Language Button Once
Press Return 3 times
You will then see the region code on screen
Use your up and down arrows to select region
Regards,
Aysaam
May 04, 2012 | RCA DRC69705 Player
Hi, I have purchased COby DVD player from US.. I cannot play any dvd as it says..'Wrong Regional Code' ..Can you tell me how to fix the issue?
Try this:
With no disc in player:
On remote control:
Press Setup
Press >>
Press Press >>I
Press I(Current region shown on screen)
Push right arrow to increment 2.. 7.. 255
(When number = 255, Press Enter)
Press Setup to finish
(Source)
Nov 05, 2010 | Coby TF-DVD7005 Portable DVD Player
Change region on Philips portable dvd player
Switch the player on
Open the tray door
Press Setup on the remote control
Select Audio
Press RIGHT ARROW
Press 2,1,2,2,2,5
Press LEFT ARROW
Press DOWN ARROW
Press 0 when the screen displays region code
Press Setup to exit
Enjoy
Mar 16, 2009 | Philips PET702 Portable DVD Player
WRONG REGION error
For me the problem was with a Philips DVD player. I Googled the make, model and "wrong region code" and got some solutions. Try this approach. Some websites offer to sell you a solution; hopefully, you should be able to avoid this!
Dec 29, 2008 | Electronics - Others
Philips DCP750/37 shows "wrong region"
Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips PET710 Portable DVD Player
WRONG Region error . Philips DVD65K
Each DVD player is designed only to read discs froma certian region of the globe, and they are labelled 1 through 6 (or ALL). Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Dec 21, 2008 | Philips PET710 Portable DVD Player
Won't pay dual screen dvd
Do a search for the model and "cracking region code." When searching for solution for my own problem, I found a forum (I think maybe on Walmart.com somewhere) where they talked about region codes for US and overseas and how to change them. Might be what you need to do.
May 29, 2008 | Polaroid 7" Two-Screen Portable DVD Player
PERMANENT UNLOCK REGION CODE FOR philips DVD PET714
I boght PET714 DVD portable DVD player.
but I couldn't watch Japanese DVD.
I'd like to unlock code.
Please tell me how to get unlock!!
Jan 12, 2008 | Televison & Video
No Disc?
Hi, i have one kind of this model.But i never faced this issue. in general, some DVD players wont recognise regional specific DVDs, we need to make the region free setting on DVD player. i suspect some thing like this. Please check on philips web site the region free stpes for this particular model. Thanks, Pavan
Sep 01, 2007 | Philips MPD850 Portable DVD Player
Philips PD7012G/37 7-Inch Dual Screen Portable DVD Player Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
