Question about Whirlpool Duet GHW9150P Front Load Washer
Pause mode stuck
Hello-
How do I reset my machine to get the pause mode unstuck???  I have tried unplugging it and that didn't work.  The control panel lights up, you can turn the dial to what cycle you want, but when you push the start button it doesn't work.  The reason I think the pause button is stuck is because the control panel is flashing and when you push the pause button it won't pause but cancels.  Can you please help??
Thank you!!!
  • Anonymous Mar 30, 2014
    I set mode then start. The door locks then runs a few seconds then just stops. The timer is still on and setting lights still on but machine won't start back up. Then won't respond to the pause button. Have to push cancel to get the door open
    Scholar:
  • 146 Answers
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Posted on Nov 06, 2007
Washer stuck in pause mode
Check the door switch. I think you have posted twice.
Thanks/Mike
Oct 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire washing machine model number 137168300a stuck in pause mode
Good Afternoon Friend, this is Z. Thank you for your inquiry!
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 12, 2014 | Frigidaire Affinity ATF7000EG
Stuck on pause will notrun
Hi Jeanen, thank you for allowing me to assist you.
Pause commonly indicates that the unit thinks that the door is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If it proves to be ineffective, try reprogramming the appliance by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit on. If resetting the power does not correct the issue, then the washer could possibly have a faulty door latch or experiencing a communication error with the control board.
Sep 16, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fafs4474lwo washer is stuck on the pause feature
Hello Claudia Clary - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective then the unit may be experiencing a communication issue with the control board, faulty keypad or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire ATF6000ES Front Load Washer
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Sep 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
Will not work at all
Press 'pause' & 'reset' together for about 5 seconds. The lock should come off.
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Mar 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Feb 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,952 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
