Question about Danby Freezers
Freezer recall Leaked
Why doesn't freezer get cold enough
If the thermostat is turned up and the freezer still remains at around 10 degrees I would suggest the system coolant has leaked or the compressor is faulty. Check that the door seals are not obstructed or broken, that will stop the freezer getting colder.
Sep 01, 2014 | Bosch Freezers
Frigidaire freezer M# ffu17f5hwh, is there a recall on control board?
Hello friend, thanks for the post!
I see that the red light stays on and your Frigidaire freezer continues to beep. From what I have researched there is no recall on the control board of FFU17F5HWH. You could try resetting your appliance, which could be done by unplugging the power cord or flipping the household circuit breaker in the off position for ten minutes. Please comment back I would like to know if this information has been helpful. I look forward to your post. -Matt
Aug 06, 2014 | Frigidaire FFU17F5H Upright Freezer
Www managemyhome com
I would suggest you have it serviced, sounds like the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair an engineer will first cut the coolant pipe and drain the existing gas and then recharge, re-pressurise and seal.
Jan 04, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer too warm
Are you referring to the internal temperature of the freezer? If so
have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
It might be that the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. If this is the case a serviceman will need to drain the existing gas and then recharge, re-pressurise and seal.
If you are referring to the outside cabinet temperature then it's probably ok and there is no fault. You would expect the outside panels of a freezer to be around room temperature or warmer as the freezer removes heat from inside the cabinet and expels it outside.
Jan 01, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer will not shut off some things frozen, bread and ice cream soft
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Can you recharge the freeon in a frigidaire upright freezer?It's not as cold as it should be!
I the freon has leaked out, this means there is a leak in your sealed system. Unless you can find the freon leak, charging the system will do no good. It will leak out again. There are many things to cause a freezer to not freeze. Is this a "Frostless" Freezer or a "Manual Defrost"?
Mar 30, 2012 | Freezers
We have a ukvi144b freezer that is not cooling the warning light is on aswell can itbe fixed?
Hi you will maybe find that it has leaked some gas or the compressor is about to go either way it may be cheaper just to replace.
Mar 19, 2011 | Smeg 3.46 cu. ft. / 98 liter Upright...
I need an Imperial freezer gasket for model UL5000ECW4 serial WB01811931.
I have the same model number and my freezer completely defrosted and won' freeze. I assume I have a leek and all the freon (correct spelling) has leaked out any suggestions? My email is bjkirkland@gmail.com.
Mar 02, 2011 | Freezers
Freezer no cooling and compressor continues running.
low on gas has leaked check acces tube or valve or any solder joints for oil traces as this is common also check if someone has pierced inside the chest to defrost freezer as this would probably dammaged the evaporator
Aug 28, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
FREEZER NOT WORKING
that is very possible if the fan and compressor are running. the best thing you can do is call maytag. its only 4 months old and is there problem to fix. Good Luck
Aug 03, 2007 | Maytag Freezer MQU2057
Freezers Logo
24 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Michael Van Der...
Michael Van Der...
David Jewell
Are you a Danby Freezer Expert? Answer questions, earn points and help others
